SOURCE: remove a door on a microwave
I wouldn't remove the door myself if I were you. If you just got the microwave, it should be under a return/replace policy, or a warranty. I would recommend returning the microwave and getting a sturdier one, as you don't know if the problem exists for all microwaves in that series, and most stores don't allow the replacement to be return/replaced.
SOURCE: Frigidaire door/power problem
Sounds like either the latch assembly or hinges too loose to activate the micro switch. TIP: Go to the web and type www.partselect.com enter your model number then scoll down to your part. Click to enlarge exploded diagram on left. Veiw enlarged diagram at top of page. You can print the entire diagram for exact assembly by holding your pointer in the upper left hand corner of diagram. Select the print icon. Now you have what you need. If you found any of these suggestions helpful, please rate my solution. D. Lange
SOURCE: my frigidaire microwave oven will not heat
YOU NEED TO CHECK THAT THE TOP ELEMENT HAS NOT BLOWN .
SOURCE: My microwave stopped working. PLEASE HELP.
In all likelihood the mangnetron has failed, or perhaps even the Power Supply. or a fault that is shutting the system down for safety reasons You need to have it serviced by a reputable service centre/man.
Ensure you get a firm "Quote" before proceeding, and remember these days the cost of repair can equal or exceed the price of a new one.
SOURCE: Frigidaire microwave oven plmv168
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Good Morning Jim Cole, thank you for your post!
From what you are describing it sounds like it could be an issue within your control panel or door switch. I would recommend having a technician out to properly diagnose your Frigidaire microwave to avoid any unnecessary part purchases. I hope this is helpful. -Matt
