Question about Frigidaire Affinity ATF7000E Front Load Washer
Error code DR comes up on my Frigidaire Affinity and won't keep running
Posted by john leyte on
Richard Roth
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
It is telling you there is something wrong with the door lock assembly. You will probably have to replace it, but check it first for a broken wire or some other problem that you can fix.
Here is a link to the part if you need it.
Here is a link to a service manual for your machine that will take you through the testing and repair process.
http://www.emaservicetips.com/pdfs/778_5995456851_Affinity_washer.pdf
Posted on Oct 17, 2012
5 Related Answers
Anonymous
SOURCE: AFFINITY ERROR CODE
door not close
Posted on Sep 09, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: error code
what is the code???
Posted on Jan 05, 2008
SOURCE: ERROR CODE E20
Just fixed mine, only I did not have to take it all a part. Just tip it over and reached in thru the opening in the bottom. Took the clamp loose with a phillips screwdriver and pulled the rubber off that contains the filter. Stuck my hand in the opening and pushed up on the filter from the bottom on the rubber container. Out came the filter and I cleaned it and pushed back down inside until it was past the lip that held it in place. Works great, took about 10 mins., not bad for a woman, huh. Thanks for the info, could not have done without your diagram and information.
Posted on Jul 26, 2008
Anonymous
  • 11 Answers
SOURCE: Frigidaire Affinity E20 error code
This issue is a clogged drain. It usually requires cleaning out the Drain filter underneath the drum assembly in your washer. If you are not handy, don't try this yourself, it will require some skill.
Joe the Plumber
Mid-Hudson Heating & Plumbing
Woodstock, NY
845 679-9158
Posted on Jan 30, 2009
Anonymous
SOURCE: Frigidaire Affinity Error Code EFO
We got the same error. After searching countless forums, we found the solution! There were socks/underwear/change built up in the pump. The water was not cycling through properly. It didn't even get passed the wash cycle. Cleaned it out and everything works fine. Plus, the error code list is INSIDE the washer! Go figure.
Posted on Feb 12, 2009
Frigidaire Affinity ATF7000E DR error code
Good Morning Friend,
I understand you are receiving a "DR" error code on your Frigidaire Affinity washer, model ATF7000E. The "DR" error code is stating that there is a possible problem with the door. This could also be a possible false error code. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Affinity ATF7000E Front Load...
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
I get the code dr
I suspect 'dr' stands for Door (error). There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 15, 2011 | Frigidaire Affinity ATF6000F Front Load...
Dr error code
“do” or “dr” - door problem. The door is not locking, the control is not able to confirm the door is locked. Might just be corrosion on the door lock connection. Or a bad door lock OR an item in the door keeping the door from locking. Manual and more here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Error Code "dr"
Dr means door problem, either some clothes is keeping it from shutting or the door switch is bad 1ff09a4.png
Mar 05, 2010 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity/dr error
dr code means door not closed
get some crc spray and spray into lock on machine
that will lube the workings and should fix problem
Mar 13, 2008 | Frigidaire ATF6000ES Front Load Washer
AFFINITY ERROR CODE
It means the door isn't shut all of the way.
Aug 17, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
651 people viewed this question
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
