Toshiba Satellite C655d-s5200 Laptop Screen 15.6 Led Bottom Left Wxga Hd 1366x768 Logo
Posted on Oct 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My toshiba satellite C655D-S5200 isn't charging?
Doesn't hold a charge
Shira
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 119 Answers
  • Posted on Aug 11, 2016
Shira
Expert
Level 2:
Cheetah:
Night Owl:
Answers
119
Questions
Helped
20544
Points
180
Your power cord may have shot its wad.
They are not expensive to replace--even order a spare if you are paying S & H anyhow.
More likely however is that you need a new battery. Those are a bit pricier!
Simple for dummies, way to make a new file
Then you shouldn't be using a computer. get your 10 year old to do it for you.
2helpful
2answers
Toshiba c655d-s5133 plugged in not charging
Dead battery? Try another cord/charger with the EXACT same power specs.
1helpful
Can you trace a stolen toshiba satellite c655d-s5200
Not that I know of.
You can install a tracking software in the computer, for in case it's stolen, but this has to be BEFORE it is stolen.
Rest assured whomever stole it will get their just reward.
Karma, you know.
Regards,
joecoolvette
1helpful
Toshiba satellite c655D-S5200 it will not charge. What should I do?
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
hope this helps
Why is my toshiba satellite c655d-s5200 screen is black and i can faintly see
Okay. Got a bright flashlight, and some tape?
OH I'M JUST KIDDING!
Primer;
An LCD screen cannot produce light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED's.
Light Emitting Diode.
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch. Average length is almost as long, as the LCD screen is in height,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 11 photos ]
A screen Inverter converts the power from the laptop, for the LCD screen.
The Toshiba Satellite C655d-s5200 uses LED's for the Backlight, and No screen Inverter,
http://www.laptopscreen.com/English/model/Toshiba/SATELLITE~C655D-S5200/
Which narrows your problem down to two possibilities;
A) Problem with the video cable
B) Problem with the LCD screen.
I state LCD screen, because you won't be replacing the LED backlighting. You have to buy the entire LCD screen assembly, as shown in one example above.
(Example is shown for reference, not advertising. You may find a better deal from a reputable dealer, also)
Video Cable:
The Video Cable is attached to the motherboard, under right about at the number 6 key, on the Keyboard.
It then goes across to the Left Hinge, and up into the Display Assembly.
From there it goes to the back of the LCD screen.
From everyday normal opening, and closing of the laptop over time, the video cable may become pinched, and pulled on.
This can create a loose connection at the motherboard side, and/or LCD screen side.
It can also cause damage to the video cable. If the sheath of the video cable shows visual apparent signs of damage, the wires inside may be damaged also. (Stretched/Broken)
Laptop off, ALL power removed, (AC adapter {Charger}, and Battery), I suggest checking the motherboard side connection first.
A visual inspection will Not do. You need to physically see, if you can plug the motherboard side plug of the video cable, into the connector on the motherboard.
A loose connection that is not apparent to the ***** eye, is all it takes to have a problem.
You can click on any photo to enlarge,
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-1.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-2.htm
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-C650-C655/disassemble-toshiba-laptop-3.htm
Stop on Step 22. Access to the motherboard side of the video cable.
A word on the Keyboard Cable, and it's connector on the motherboard; (Steps 9, 10, and 11),
The Keyboard Cable stays with the Keyboard. It removes from the motherboard connector. The Keyboard Cable has NO plug, or connector on the motherboard end.
The Keyboard Cable is a FFC. Flat Flex Cable.
It has flat gold plated contact strips on the motherboard end.
The motherboard connector is a ZIF connector. Zero Insertion Force.
In Step 11 you can plainly see this connector.
Has a large white rectangular BODY on bottom.
The smaller rectangular shaped piece on top is the Locking Bar.
The Locking Bar does NOT completely remove from the Body.
If it does it is broken, and means motherboard replacement.
Hence why I am being so detailed.
I am sure you use great finesse, but wanted to advise you in advance of the 'danger'.
The Locking Bar is moved towards the LCD screen, and as advised about 1 millimeter. ( -> O <-)
There are Tabs on the Locking Bar. One on each side. Usual procedure is to use your thumbnails on these Tabs, and ease the Locking Bar forward.
Now gently tug on the Keyboard Cable. You may have to gently move it side, to side, to break the Keyboard Cable loose. They sometimes get stuck over time.
Pretty stiff? Better check to see if you have the Locking Bar fully unlocked.
The Keyboard Cable MUST go back in the same position, and through the same plastic Latches and Channels.
(As do all the cables, or you may pinch them, and also will not be able to get the laptop back together correctly again)
Make a mark on one side of the cable, (Away from the gold plated flat contact strips), and a matching mark on the ZIF connector of the motherboard, if you need to.
You can slip the Keyboard Cable back in, Ram Memory, DVD drive, and Battery, and reconnect the AC adapter, to see if this was the problem.
Still no?
Check the LCD screen side connector of the video cable. Is it tight?
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A665-A665D-A660-A660D/remove-replace-lcd-screen.htm
LCD screen connected, turn the laptop on.
Was this the problem?
No?
Even if there are no apparent signs of damage, you may wish to take the video cable down to the nearest 'Mom and pop' computer store, and ask them to check it for continuity. This way you can see if any wires are broken inside. (Labor charge may be free to $5)
(My thinking is if you go to a large computer repair shop, they are going to want to repair the laptop, or sell you an LCD screen, or a new laptop. "Oh that old thing? For 2995 I can put you in the seat of this baby!" )
Or since the video cable is very economical, you may wish to just replace it.
Just one example from a quick search,
http://www.ebay.com/itm/Toshiba-Satellite-C655D-6017B0265601-LCD-Video-Cable-Genuine-OEM-Laptop-Tested-/290753862740?pt=US_Video_Cables_Adapters&hash=item43b247dc54
[Black end on right is motherboard side, gold colored end on left is LCD screen side ]
Video Cable ruled out your problem is the LCD screen, or to be more specific, the LED backlighting.
Replace the LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
Toshiba c655d - s5200 wont start up. i get a black screen that says no bootable disk
sounds like you have a bad hard drive,,try putting a bootable cd and start it like that,or at the start up hit the f2 key and go into the setup and seee if there is a hard drive loaded
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
