Question about Supersonic 15 in. LCD TV
Sound plays on some stations and not others- how to fix this?
All of a sudden the sound plays on some tv stations and not others. Looked in manual but couldn't find a solution. I must have pressed a button by mistake.
Posted by twinie2 on
Jayesh Panchal
    Sergeant:
    Champion:
  • Supersonic Expert
  • 279 Answers
Go to Menu select Set up change Color System to Auto.
Posted on Jul 30, 2014
Tom Russo
    New Friend:
  • 30 Answers
Look for MTS or SAP button on remote or in tv menu depending on make--you have it set to SAP--change it to mono or stereo
Posted on Oct 15, 2012
  • twinie2
    twinie2 Oct 16, 2012
    Tom, there is no mts or sap button anywhere on remote. I looked in menu. Nothing in there either. Help!
  • twinie2
    Got it finally- thx!!
I CANNOT GET MY SONY TV #KD-34XBR960 TO PLAY THROUGH THIS RECEIVER.
TV's don't play through receivers. TV sound might. If it comes from a Cable Box, connect the Cable Box digital audio to the receiver as you would any other high-end audio device; and the Cable Box's standard analog audio to the TV for those times you don't need the Technics audio capabilites (like watching news).
Have you looked at the manuals?
Apr 03, 2011 | Technics SA-DX750 Receiver
My radio won't play tv channel 4 sound or any other! please tell me if im doing something wrong!
Since June of last year all television broadcasting switched over to digital signals. Without a converter your radio will not receive any of the stations sound channels. Impossible to modify, only a converter will bring the stations in.
Feb 05, 2010 | Emerson RP6250 AM/FM/Weather/TV Radio
BD/DVD NO SOUND SCREEN SAYS UNBLOCK
I solved the problem myself. I obviously didn't read the manual properly. All I had to do was change the audio settings on the Play Station.
Jun 02, 2009 | Sony STR-DG510 Receiver
No sound when playing a tape and wont tune in to the tv stations
No sound on playback is normally the scart lead not fully in either the vcr end or tv
Apr 27, 2009 | Panasonic Televison & Video
No sound on one station
try to adjust in remote control the fine tuning or if there is a system in audio you can try it also.
Feb 20, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Cant get my viera linked panasonic to play through surround sound
I had the same problem, so i contacted panasonic, I am including the email they sent me.
For connections of audio, so that you can hear all tv audio through the
surround system, connect either an optical audio cable or red & white
analog audio cables from the tv to the home theater. If you are using
optical audio, there is a plug on back of tv labeled for digital audio
output and an input on the surround sound system. If you plan on using
analog red and white, use the PROG OUT red and white output jacks on the
back of the tv to the AUX input on the home theater.
For video connections, to get HD you will need to be using either HDMI or
Component cables. HDMI is the cable that will provided 1080p signal (the
best HD signal), but if the source does not output 1080p, then your tv
will not display 1080p. Most cable boxes output at 1080i or 720p when on
HD stations. This signal still provides great picture quality, but HDMI is
not needed to get these HD signals. You can use component cables for your
cable box and the DVD player output to the tv for video. HDMI might give
you a slightly better picture quality but the signal will be the same.
To make the connection, you will want to connect from the cable box to the
tv (component or hdmi). Also from the home theater system to the tv using
hdmi or the video cables from component (red, blue, & green cables).
We hope this information is helpful to you.
Thank You,
Panasonic Consumer
Dec 16, 2008 | Panasonic Home Theater System System
VCR tuning to TV stations
Sorry I hadnt repied,have been away.
Once you have found that the vid plays ok on a certain channel,press stop on vid,so noyhings playing,then there must be a scan or search button on remote,its important you are on the channel that the vid plays on ,when doing it....I looked for a manual bet couldnt find one,
Rod
Aug 30, 2008 | Televison & Video
Car DVD player sound quit working
Best thing to do in this thing is contact panasonic to see if its compadable with all these differaqnt places your going..see www.panasonic.com or call emc at 1-800-782-4362 they will fix ya up and tighten that sound gap!!!!
Mar 07, 2006 | EMC POWER SUPPLY ASSY-380WATTS Power...
Supersonic  15 in. LCD TV Logo
79 people viewed this question
Top Supersonic Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Kardoc
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
