The problem is that the picture has lines through it. I think it's the convergence that the green color does not line up. I would like to fix it myself. Can you give se advice or picture how do do it
Posted by jason quirk on
Tom Russo
    New Friend:
  • 30 Answers
Convergence ics stk392-120 most likely-- you will need 2
Posted on Oct 15, 2012
5 Related Answers
Anonymous
  • 320 Answers
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Posted on Oct 18, 2008
Anonymous
  • 59 Answers
SOURCE: no picture vertical colored lines blinking
im afraid to say your display has gone contact funai they should be able to help you replace the display.
Posted on Mar 10, 2009
Cary Leonardt
  • 304 Answers
SOURCE: Pink and green lines and double picture.
Replace the main bd. Have a trained Samsung tech troubleshoot to confirm.
Posted on Jul 17, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: colorful vertical lines on screen
more likely to be bad LCD panel (very expensive), but you can try replacing the LCD controller first (around $80~100).
Posted on Dec 01, 2009
freelance-au
Darren Law
  • 131 Answers
SOURCE: LG RU-42PX10C Plasma TV picture had colored lines & went black...
This will be your Y SUSTAIN board on the left hand side when you take the back off.
Plenty available on ebay, Very easy fix
Posted on Mar 05, 2010
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
If looking directly into screen you see all three lights Red Green Blue next to each other illuminating parts of the screen that color.
U mean on tv screen colors lines R,G,B colors are all mixed up and mis alignments all those R,G,B colors lines on the tv screen?Yes,u have colors shadow picture or 3D picture look alike?Yes,ur tv have a problems known as a convergence problems,it is dead.This tv convergence board it is dead must require replacing 2 STK of convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv picture convergence problems.The shop will cost u like $300-350 for parts and labors.
Jun 22, 2011 | Panasonic PT-52DL52 52" Rear Projection...
Hello, I have a 2005 Sony KP-51WS520 Rear Projection TV. Recently, the green colors all become a yellowish/orangish color. When you are watching a baseball game the grass is a orangish color. ...
DLP tvs have a design weakness,the problems it is call a convergence problems,it is dead.This convergence problems,will have happen many times through out the tv live.The tv have a colors R,G,B lines misalignments,have colors shadow pictures or 3D pictures look alike?Yes,than the tv board,that call the tv convergence board it is dead.The tv convergence board,must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv colors picture convergencce problems.The tvs shops will cost u like $300-350 for parts and labors.
May 24, 2011 | Sony KP-51WS520 51" Rear Projection...
I cant line the red and green crosses up left and right but i can move them up and down. I have two pics in diferent colors
The tv have a convergence problems,it is dead.Tv have colors lines like R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?Yes,than the tv convergence board it is dead.The tv convergence board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
May 09, 2011 | Philips Magnavox 51MP392H Rear Projection...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Picture is unstable (jittery) colors (especially red & green) are smeared. Picture seems to have aprox. 4 horizontal not in line boxes.
Ur tv have a problems known as a convergence problems it dead.Tv have colors lines like R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Tv have a dead convergence board,board must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the convergence board to solved the tv picture convergence problems.The shop,will coat u like $300-350 for parts and labors.
Jan 31, 2011 | Hitachi 61SWX10B 61" Rear Projection...
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
I have red and green shadows. I tried using the Converge Red/Blue and Multipoint Red/Blue functions as described in the manual but neither worked
The tv 100% have convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv have a dead convergence board,the 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be change to fix the tv convergence board to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Dec 10, 2010 | Philips Televison & Video
Convergence is out...trying to manually adjust but only have blue and green lines....no red...how can i fix this?
Tv have 100% convergence problems,it dead.The tv have colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 22, 2010 | JVC AV-56WP74 56" Rear Projection...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
