JVC AV-27F802 27" TV Logo
Question about JVC AV-27F802 27" TV
No picture just sound
There is sound and cable menu/info but no TV stations, just black screen
Posted by smaricle on
    Top Expert:
  • JVC Master
  • 76,851 Answers
Check and replace damaged component/s in its horizontal output section circuit. Check LOT and horizontal output transistor.
Posted on Oct 16, 2012
4 Related Answers
Anonymous
  • 934 Answers
SOURCE: black box shows on tv with cable or dvd, not vhs
Good for you!! CONGRADULATIONS
Posted on Jun 10, 2007
Anonymous
  • 54 Answers
SOURCE: picture
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Posted on Apr 14, 2008
Whip Lashaway
  • 55 Answers
SOURCE: AV 35750 no images only sound with cable, images & sound with DVD
Make sure the cable is on when you autoscan. If the autoscan doesn't see it,manually inputing won't get you there. Make sure you have the correct band selected when you autoscan.
Posted on Mar 09, 2009
Chi Chu
  • 8457 Answers
SOURCE: black rectangular box on screen from doing menu
Take ur tv remote go to menu check the captioning functions turn all CC1,2,3 off and all txt off too.Yes,text functions is on,that why u getting a big black block flashing on ur screen.
Posted on Mar 28, 2010
1helpful
Samsung UN65NU6070 4K LED TV. What could cause no picture?
A black TV screen may just be a sign that the TV is turned off, although if it is producing sound then you know that's not the case. When your TV has a black screen even when it's on, it could be possible it could actually be your external device and not your TV.
-Reset ALL components by unplugging them about for 5 minutes including the TV. -Be sure all COAX CABLES and HDMI CABLES are tight and properly connected. -If you CAN pull up the TV MENU when you have the black screen, update your TV's firmware to be sure your TV is up to date and rule out the TV as the problem.
Sound not picture
A few questions:
Are you using this TV directly on a cable line of do you have a cable box or satellite receiver connected?
Do you have sound and no picture on the AV inputs as well, or only on TV channels?
Is there anything on the screen or is it completely black? Has the picture collapsed to a single line across the screen? Is there a picture but it's distorted?
Does the on-screen menu and channel number display properly?
With a little more information I might be able to help you with this.
2answers
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
1helpful
No picture; black screen; only red light blinking.
take to a service station i think just changing the displsy IC would do . but check in service centre
1helpful
No picture screen is blue
If you use RF cable, need to change brand new cable.
But, before that need chck the status of cable connector.
2answers
Zenith 13in flat screen tv has no picture...
Welcome to FIXya
did you try to unplug it and plug it back in
or maybe goto the menu and try to redo the stations
make sure you have the tv pluged in to a power strip
hope this idea helps out if not please let me know have a good day:)
Archos 604 dvr blank screen
It sounds to me like there's an Component A/V cable issue. Please re-check the cable connections making sure they are connected correctly. When using the docking station and Component A/V cables you must be sure the cables are connected with their corresponding colors on the back of the DVR Docking Station. Also check that the format of the recording is compatible with the "TV Standard" in the settings menu of your Archos. It will be either NTSC (USA) or PAL (Europe). Be sure to check the Video Output Settings of the Archos to be sure it is set to the same type of cables you are using- component, RGB, s-video or composite. Good luck!
No picture but sound
How did the cable person hook up the cable? Was it thru an rf connector and you need to put the tv on A channel . Or are there video and audio cables from the cable box to the tv? We need to have more info please. Thanks
Top JVC Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
