Question about Breitling Aerospace 455 Wrist Watch
Backlight for my breitling aerospace has stopped working, otherwise watch is working perfectly.
It was just serviced july 2011 and I would like to avoid a costly shipping/insurance fee to return to the service center if it only requires a simple repair (ie-replace batter.) The watch is no longer under warranty. Suggestions??
Posted by JenM on
  • JenM Oct 15, 2012
    Also, this watch is 5 1/2 years old and was serviced at a Breitling maintenance center July 2011.
masud
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Breitling Master
  • 582 Answers
I should just order a whole new analog works...is he just trying to make some money off me?
Posted on May 18, 2017
Anthony Figueroa
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
I am in South Korea. My back light has stopped working and I took it to the dealer/service office in Seoul and asked them if they could repair it. Then took it apart and said everything works find, but for the back light, I should just order a whole new analog works...is he just trying to make some money off me?
Posted on May 15, 2017
5 Related Answers
Bruce Robin
  • 300 Answers
SOURCE: Stopped working and all digital figures displayed!
If the display is not dim the battery is probably OK. Try removing the battery, test it anyway, and after a minute or two replace it (I'd use a new one anyway) and see if the problem is cleared. Sometimes just power cycling will "reboot" the watch. If that doesn't do it I'm afraid it will need to visit a Breitling service center.
Posted on Apr 18, 2010
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: Breitling Aerospace -setting T2
Here is a link for all settings:
vbr.com/docu/breitling4.htm
Posted on Dec 18, 2008
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: My breitling chronomat stops working even while
Every mechanical watch must be serviced within 2 - 7 years depending on what movement is is fitted.
Find your nearest watch repair shop and as for overhaul ( this is how we call full service of any watch).
Reasons for stopping can be numerous, but usually it is gummed oil, dust particles, and wear and tear.
Rate me, please.
Posted on Apr 08, 2009
David Tolond
  • 2501 Answers
SOURCE: how can i replace the battery on a Breitling
I suggest that you got to "www.breitling.com" and after getting past the pretty pictures you click on "maintenance centers" and find the one nearest you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
One fairly frequent cry for help is because the owner can't get the back on again. Also since watches frequently include gaskets to keep water out, difficulty can be experienced in fitting the back and maintaining the seal.
Posted on Feb 17, 2010
Anonymous
  • 93 Answers
SOURCE: It's very difficult to adjust my breitling
Normally this is from the crown and case tube being dirty. This slows down the rate at which the crown can be turned so the switch inside cannot get triggered to move the hands quicker. Sometimes the turning action can also be so that the switches do not actually 'see' the crown was turned and so the hands do not move.
The solution is to have your watch serviced.
Hope this helps.
Ken Kotoski
Yellowstone Watch Inc.
www.yellowstonewatch.com
Posted on Feb 19, 2010
Testimonial: "Thanks a lot."
Alarm randomly goes off and I have alarm turned off
http://www.breitling.com/en/service/user-manuals/
If it does not work as per the manual you probably need a replacement module from Breitling service which wont be cheap!
Mar 03, 2014 | Breitling Aerospace Superquartz E75362
How to set time on breitling aerospace
press button till in time mode then pull out crown wheel and rotate slowly to adjust minutes or spin quickly to adjust an hour at a time.
If the digital and hands don't agree the process for correcting this is in the manual on the link above.
Nov 06, 2012 | Breitling Aerospace 455 Wrist Watch
Apr 15, 2010 | Breitling Aerospace 455 Wrist Watch
Breitling aerospace stap
If it is the spring that connects the watch to the lugs, It is called a spring bar. You can easily get some on ebay . Or just got o a local independent watchmakrer shouldnt charge you more than $10 to put a new set of spring bars on.
Dec 22, 2008 | Breitling Aerospace 455 Wrist Watch
How do I set this watch
There is an on-line manual for the Breitling Aerospace at http://vbr.com/doku/breitling4.htm
Oct 13, 2008 | Breitling Aerospace 455 Wrist Watch
Sep 07, 2008 | Breitling Aerospace 455 Wrist Watch
Breitling Aerospace 455 Wrist Watch Logo
1,418 people viewed this question
Top Breitling Watches Experts
Bruce Robin
Janelle Schoonover
Janelle Schoonover
deton8 von Splosion
Are you a Breitling Watch Expert? Answer questions, earn points and help others
