Question about HP DeskJet F4280 All In One Printer InkJet
Getting message clean ink stains from printer. how?
2 Related Answers
Anonymous
  • 163 Answers
SOURCE: printing problems
It probably requires the Fuser rollers or the PCU drum cleaning, your first port of call would be to download the manuals from the HP Support website:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=uk&docIndexId=64902&taskId=101&prodTypeId=18972&prodSeriesId=28861
Posted on Mar 03, 2009
SOURCE: incompatible ink cartridge ho 4500
I have had simlar problems with other brand inks on epson printer a guy in a computer shop were I bought the ink from told me to take the ink out wipe the chip with a clean cloth wipe in one direction, also your ink when new has a piece of thin plastic that now has a small hole in it as you have taken it out from printer put a small piece of sellotape over hole other wise printer will think you are putting old cartridge in again you might need to do this a few times, but bear in mind that this was done with an epson printer but it doe's solve the problem when it crops up from time to time.
Posted on Feb 25, 2012
How do I undo unable to clean 46 message
This error is for the Waste Ink Station.
The Waste Ink Station is full. This requires a full dismantle of the machine to clean out and then a reset process run to clear the waste ink counter.
Sep 09, 2014 | Brother MFC-790CW Multifunction Printer
Big black vertical line on the back of the paper. Have cleaned the nozzle several times as directed by online instructions, but still ink line tehre, you say clean the nozzle with a stick, but you dont say...
Any ink on back of paper is a stain and not a print. So open the cover and look carefully and well into the printer, the path of the paper, and you will most likely see ink stain about the area where the stain occurs and wipe thoroughly with tissue a soft cloth.
Good luck 7 God bless!
Mar 03, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
New kodak esp5250
Try to clean the printhead
Press Home > Maintenance > Clean printhead
If still the same issue
Visit www.kodak.com/go/itg
IF still same issue call or chat with tech support and get the printhead replaced free of charge
Jan 03, 2010 | Kodak ESP 5 Printer
Cannon mp180 ink reservoir full
If you do a google search on this you will find all the instructions you need to sort it out. - you will get ink all over your fingers though.
Sep 10, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Clean the ink absorber
The waste Ink absorber is a small, deep sponge, located where the cartridges rest when the printer is idle. Although you can technically reset the counter on the amount of ink held in the absorber, if you overfill it, over time you will start to have color staining on your cartridges, since your carts clean up on it after every cycle, at the extreme, you can have ink residue build up under your printer. Online printer supply shops can sell you a replacement absorber cheap.
. You will need some rubber gloves, rubbing alcohol, and a small prying tool.
1) Locate the absorber at the bottom right of the cartridge path
2) With gloves on, pry up the absorber (if you have the almost full warning, be prepared for some good splatter.)
3) In a small dish with a small amount of rubbing alcohol, shake the absorber around for a short while to moisten the outer ink.
4) Rinse the absorber in a metal sink (porcelain can stain) with more alcohol, then leave it to dry.
5) Replace and make sure the absorber is seated the same as when you took it out.
Then you want to reset the counter for the absorber.
1) Enter the Service Menu by keying = Menu,Scan,Copy,Scan.
2) Use the arrows to navigate to Service Menu Counter Access. then press OK.
3) Use the arrows to navigate to ABS-M Dot Count, press Copy.
4) Use the arrows until the count is zero, press OK then Reset.
5) For good measure, turn the printer off and on.
hope this helps
Jan 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Printer Ink is Low
If had refilled the ink then this printer as in build sensor which works only once , that reasons your getting this message if your using original Lexmark cart then if your getting this message then you can contact lexmark get the cart replaced as the cart comes with 6 months warranty.
May 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
MFC-5840CN "unable to clean" and "machine code 50"
you have to fix the encoder strip into right position within the ph carrier! do push the head left/right to see if there are waves infront of it. if so, fix the strip into position!
BTW:
If you refill your carts use 2ml glycerol (from drugstore) with 10ml dye-ink: mix well before refilling. For bk use 1,5ml glycerol with 20ml bk dye-ink.
The glycerol prefents the ph/nozzels and tubesystem from drying up!
Apr 21, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC440CN
Did you use generic ink carts? If yes ink has stained the led control. Try to clean it by help of a towel. In some cases this will help. If not, the led control needs replacing!
Another solution:
Did you answer the question given by printer when changing the cart?
You might take all carts out, unplug machine from power outlet. replug to power. wait until machine demands carts. Place cart in and answer question.
Feb 22, 2008 | Brother MultiFunction Center MFC-440CN...
HP DeskJet F4280 All In One Printer InkJet Logo
717 people viewed this question
Ekse
efs_perpends
efs_perpends
