Question about JVC MX-J30 CD Shelf System
JVC MX-C33 Tape Drive Problem
Both tape decks are inopperative. i believe the right one needs a drive belt. The left one may need a replacement part. The door won't open, appears one of the idler rollers(spring loaded) is not in correct position. It's not under spring tension, seems to be hanging. can I buy replacement parts? Drive belts....Idler Roller...Idler Shaft...etc?
Posted by milite on
5 Related Answers
Anonymous
  • 93 Answers
SOURCE: CD Changer & Tape Deck
Check for dirt on CD laser lenses. Also transmission on tape player.
Posted on Oct 03, 2007
Anonymous
SOURCE: tape deck not working
I had the same problem and fixed it. It's simple: Open the case by removing the 6 screw on the outline back of the system and the 2 black ones on each sides. For me, it was the right tape who were problematic, so I started the player to see what gear was turning badly. The problem is: that gear don't have enough power to complete his action, so give it an additional (but not to much) power with your hand to complete his action and the system must succeed the action and stop running.
Posted on Jan 15, 2008
mikedurland
Mike Durland
  • 481 Answers
SOURCE: idler pulley arm
there is a certain way that the belt is supposed to loop around the tensioner and motor. this picture might help.b00f604.jpg
Posted on Jul 20, 2008
Anonymous
SOURCE: HOW DO I UNLATCH THE IDLER ROLLER LOCK?
Push the little white latch..you will notice a spring mechanism inside. Once you push on the latch the spring will move and release the lock.
Posted on Dec 15, 2009
Anonymous
  • 3 Answers
SOURCE: Tape player not working
i have had this problem with mine what you can try is when it does the clicking sound you can take your fingers reach under the black part w/ the head and gently push up when it clicks if you hear more clicks and the part moves then try pushing and holding the tape switch located at the left or right top corners of the player then press play if the head goes up but the clicks 3 times fallowed by 6 clicks the repeat the process. what is going on is if they r not use it tends to lock up
Posted on Jan 24, 2010
Left Deck Door Stuck Shut on Cassette Deck
Hi what has happened is when you pressed play the tape head that reads the tape has come up as normal this locks the door as you cant open it when its playing but instead of the tape head releasing and going back down into start possition it has become jammed in the tape itself.
You have two options turn off at mains and give it a gentle bang a couple of times this might free the tape and let the head go back to start possition its upto you how hard you tap it but doing this usually works and will allow you to get the tape out failing this then its going to be a case of stripping it down till you can get access to the tape head and be able to free it from the tape allowing door to open let me know how you get on ok and if you need further assistance
Feb 07, 2008 | Audio Players & Recorders
Replacement drive belts for Sony HTC-H2900 tape deck
CPC, Chas Hyde, Willow Vale, Wizard.
Or you can measure the diameter of the belt and enter it into google. IE 60mm drive belt.
Dec 29, 2009 | Sony Audio Players & Recorders
Sony deck will not drive tape
The belt is worn out already, so it need to be change. you can dissemble the deck then bring the tape mechanism to a shop and replace the belts.This will solve the problem.
Aug 24, 2009 | Audio Players & Recorders
BOTH doors jammed on TC-WE605S
Some tape decks are belt-drive. If the belt is worn, it will either break or jump the cog and you will experience these kinds of problems. That's what happened with my Sony ES deck recently and I couldn't even eject the tape until I got the belt replaced.
Jul 30, 2009 | Sony Audio Players & Recorders
I need replacement drive belts for an Onkyo
i bought some today from **** smith electronic store , i paid $7.97 for a pack of ten assorted sizes
May 18, 2009 | Audio Players & Recorders
there are small rubber belts that drive the tape spindle that makes the tape play! Over time these stretch and become loose and make the tapes play slowly and even shut down (replace belts and it should be fine) these belts are located in back of tape spindel and are about two inches long!
Please rate my answer and keep this site FREE!
Dec 31, 2008 | JVC MX-J30 CD Shelf System
{11-30-13)
TO FIX THE CASSETTE DECK BELT PROBLEMS:
- Disassemble the player.
(you will need only one, long, phillips head screwdriver $5.00)
[It is a tedious job. (first,study how it is put together) There are 6 screws on the back - three down deep holes, three at the bottom, and two dark colored ones on the side. Once the front covering is off, then you start the process to get at the Cassette deck. You will have to unscrew a ground wire; pull the "tape" connections and one wire bundle snap fitting; and then unscrew the two screws on the back, near where the wires for the speaker connections are placed... then remove the Cassette Deck.]
{I sat in my recliner with the whole thing in my lap as i worked with a foot stool near by to put things as they came apart... and i used a metal salad bowl to through the screws into as i went along.}
- Study the drive mechanism.
- See where the drive pulleys are.
- Use small elastic bands to replace the broken belts.
(small = 1/2 inch diameter ... the size of your little finger, but will stretch out to two inches or so.)
https://www.google.com/search?q=small+elastic+bands&espv=210&es_sm=122&tbm=isch&tbo=u&source=univ&sa=X&ei=6rGaUrTlCszloASJw4KQBw&ved=0CGYQsAQ
I happened to have these on hand:
- I did this on my JVC PC-XC70BK and it worked.
- Both the player-side and record-side decks had broken belts.
[The fast forward and rewind wouldn't work on either side.]
(Per each deck: one drives play, one belt drives both Rewind & Forward)
- Now both decks work.
TO FIX THE CD PLAYER ISSUE:
- My guess is the laser pick up is dirty (because they all face upward and oily film builds up on them).
- First try a disk cleaner with a brush on the underside of it.
- If that doesn't work, then (after taking off the front plastic cover plate {see above}), you can see where the upward pointing laser lens is. If you can, use Rubbing Alcohol on the end of a Q-Tip to probe into the area and thoroughly clean its surface. Then wipe it clean with a dry Q-Tip.
- If you can't get at the laser lens, then Disassemble the Unite.
[There is another ground wire that must be unscrewed from the deck assembly. And there is the issue of the tape connections leading to the top part of the unit ... they will flop around and fall out of their place once you have pulled them from the connectors ... with a bit of observation you can get them back correctly.]
- Unscrew two screws at the back ... then pull out the tray assembly.
.... then go as far in the disassembly as you need to so you can swab the laser lens with the Rubbing Alcohol.
- Re-assemble. I had one screw left over.
... ROTFL but i know where it goes and i don't care to get it there... so to hell with it, right?
Everything works fine now. Not bad for a 17 year old piece of equipment that has a Ten CD storage tray... that you can't get anymore... right?
Oct 02, 2007 | JVC MX-J900 CD Shelf System
Cassette player on mx-d302t
Hi As you know cassette decks have been around along time, and as such they are fairly robust. The vast majority of the time, problems like you are describing are the result of a broken drive belt, or bad capstan motor. This is not true for all, but if you have favorite tapes you wish to play, you need the deck fixed, and if the problem is drive belt or motor, the repair normally should not be hugely expensive. Hope this helps, good luck!
Feb 23, 2007 | JVC TD-W118 Single Cassette Deck
JVC MX-J30 CD Shelf System Logo
133 people viewed this question
Top JVC Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
