Im trying to install the sims 3 game onto my powerbook G4 but it states that its "not supported on this system" is there a way around this?
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
It will not work on a PowerPC based Mac. You need to have at least an Intel based Mac. MacBook or better.
It's system requirements are as follows, and your machine isn't close to this:
FOR MAC OS X
SOURCE: brother mfc210c printer driver
I believe your brother printer uses one driver for fax/scan and another driver for printing. It might seem like you haven't installed the printer driver, only the fax/scan driver. You should find the driver file and the instruction on this brother.com page:
PS: the driver linked to above is for os 10.4. You might want to search for a different version if you have a newer/older OS.
If the link doesn't work, search for the driver from brother.com's site and download and install the driver by following their 12 points instruction. Good luck!
SOURCE: Powerbook g4 will not turn on
pull the battery out, put it back in, plug the mac in, and hold down the power key till u hear the chimb
SOURCE: PowerBook G4 won't eject cd by any means found on apple support
If you can hear that it's trying, it might be getting pinched while trying to eject, especially if something pressed down on the case at that spot. Try gently widening the opening with a flat head screwdriver while you are ejecting the CD. just put the driver in and twist a bit to widen the slot. Also, check to make sure that the fuzzy stuff that brushes off the disk when you insert it - and keeps out dust - hasn't been damaged. If it is partially missing, the missing part may be inside, keeping the CD from ejecting.
SOURCE: my mac powerbook g4 12'' wont chime or boot just
Resetting PRAM and NVRAM
Your computer's PRAM and the NVRAM are reset to the default values. The clock settings may be reset to a default date on some models.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
