This pod has sat around 4 about six months when we went to charge it we got a disabled message & pod was locked
Hi mythreebrats
If you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data.
Please take time to rate me
Bud
SOURCE: How do I Unlock Ipod screen if I forgot the 4 digit password?
There are basically three ways to unlock the Screen Lock on your iPod:
If your iPod is simply frozen, follow my instructions for an iPod Lockup Reset.
Everything on your iPod will be erased.
This should not be a problem if you have all of your songs, videos, and other media stored in iTunes and you can synchronize once again after getting the iPod unlocked. Besides, if you don’t unlock your iPod it’s useless right? Learn how to Restore your iPod using the instructions from Apple’s site.
or
I've tried the below method, and my music is still intact]
Step:
1. Plug in ipod.
2. Open “My Computer”
3. Look for the removable device (which is your ipod).
4. Open the folder, search for this hidden file : _locked.
rename or remove(delete) this file.
5. Eject your ipod.
Done.
SOURCE: 8GB iPod Touch Disabled
Thanks to everyone who provided solution inputs. I finally have my iPod back. The solution is: 1. Turn of your iPod. 2. While holding down the 'Home' button, connect to iTunes WARNING: Doing this will return your iPod back to original 'out of the box' settings and you will lose everything. On the bright side, you get a 'fresh' start and it will auto update to the most recent software version. Good luck!
SOURCE: won't charge on Bose SoundDock
You're not doing anything wrong. Newer iPods and the iPhone require accessories that were specifically designed for them. For example, the iPod interface in my car will not charge my iPhone, however, I can still play music through it.
The only solution is to: 1: Buy a SoundDock II or 2: Charge your ipod seperately.
you will have to restore your ipod to factory default settings in itunes.
or you can jailbreak the ipod with software like quickpwn.
Here is how to restore your ipod in itunes.
You will need to put the itouch in DFU/Recovery mode to get it to connect.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Plug the
usb cable into the Ipod and NOT into the computer.
Hold the
Home Button down for 5 second (do not release it)
Then
Press and hold the Power Button for approx 10 secs (count them out)
Your iPod
will reboot.
Release
the power button and continue holding the Home button for an additional 27secs.
You may
see the screen go blank or not.
Plug the
USB end into the computer with itunes open.
Your ipod
will mount in recovery mode.
Restore
it and Your all set.
if you need any further help let me know.
Good Luck
SOURCE: i forgot my ipod touch 4 digit password and now
here you go, in detailed steps:
Hope this helped! ^_^ Have a great day~
