Question about Toshiba Ct-90302 Remote Control
Ct90302, not working, what to check?
Stopped working, suspect a button was pushed and don't know how to fix it
Posted by Carole Garrett on
Sylvia Bean Lay
    New Friend:
NON RESPONSIVE, CHANGED BATTERIES. CANNOT TURN OFF AND ON.
Posted on Dec 01, 2012
  • Carole Garrett Dec 03, 2012
    It wasn't the batteries that were causing the problem. However, this response prompted me to check the function buttons and solve the problem.
I own a 2001 Chevy unpalatable and it work fine and everything but the blinkers don't wanna seem to work properly its like 95% they don't work as for the other 5% the blinkers only wanna work when...
Make sure all outside blinkers are flashing at one speed, if not check the bulbs and all connections, If that doesn't work check flasher
2answers
Whirlpool Cabrio dryer is making a really loud noise and how do I fix it?
stephanie, the first thing you suspect is the fan belt. It could be slipping. 2nd suspect is the drum shaft that is misaligned. If you know what & how you are doing, you have to take the machine apart, find & replace parts. If you can't or don't know how, I suggest a repair man. If the repair is more then the value, worth of the machine, you should get another.I hope that this works
Nov 04, 2012 • Dryers
1helpful
Washing cycle timer display slows/stops
sound like the pump is at fault still it might still work but it sounds like its an earth fault with the pump but some time by replacing it don't all ways work its normally the board at fault as well an expensive job OK
Fix selector button
Best word of advice...if you don't know, call an appliance tech. It will save you alot more time.
1helpful
Brake lights & Hazzard lights don't work; fuse ok... High mounted center brake light works... Turn signals work...suspect problem is multifunction lever Power drain to battery constant...2...
As for the brake lights push brake pedal down while pushing on and wiggling the hazard switch.If the brake lights come on then replace the multi-function switch.
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Gaggia Titanium - the button for a small coffee has stopped working. Can I do anything to fix it?
Hi Try reprogramming the machine. Push and hold the button for the coffee you want, but hold it all the way through the process. Don't release the button until you get the amount of coffee you want for that button, then release the button. That should get you the same amount next time. You can do this for each coffee button. If that didn't fix it you might have a bad flow meter.
My wireless Logitech mouse stopped performing. I changed batteries. the red light comes on even before I changed the battery. I have had it about 3 months. Wal Mart told me to look on the back of mouse. ...
So much for Wal-Mart tech support.
If your mouse is not working, first check the batteries to be sure they are good.
You wireless mouse has a USB "antenna" or sending unit. It may have a button on it that says "connect." If so, push it.
The mouse itself has a little button on the bottom that says "connect."
Push that one next. It should now work.
If it doesn't, switch USB ports and try again.
And no, we don't charge for this answer.
5helpful
3answers
The stop button on my record player doesn't stop the record from spinning and the needle arm won't play through an entire record
hey there Jack, I have the exact same turntable and had the exact same problem. It's a pretty simple fix.
The control arm for the stop button,more then likely, got pushed a bit too far back.
Now bare with me, because I don't know the names of the mechanisms, but I'll try to make it sound simple.
First you're going to take off plate and belt, because you're going to be taking off the bottom cover of your turntable. If you don't remove the plate & belt, when you flip over the turntable, it's all going to fall and you could damage your belt.
Next your going to flip over the turntable and remove the screws that are holding on the bottom cover on. I think there are 5 of them.
Now that the cover is off, look at where the play and stop buttons are. Follow the thin metal arms that are connected to them. They should end at a white plastic piece (sorry, I don't know the name of it). Now check if the stop arm is hooked behind it or if it's pressed against the front of it. The stop arm should be RESTING ON THE FRONT of the white plastic piece.
If it's hooked behind the plastic piece, carefully pull it out and then place it against the front of the white plastic piece and you should be good to go.
Toshiba Ct-90302 Remote Control Logo
Top Toshiba Televison & Video Experts
 Grubhead
Grubhead
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
