What make you thinl k it is harddrive
SOURCE: Audio Dead/silent
If you can open CPU casing the look under the motherboard, see if you can find the Chipset of your Sound Device, it is usually start with ICON and Model Number, like ADI1987, CMI3798, something like that. And if you found it, then post the chipset model and i will be happy and glad to help you find the proper driver for it.
-mrsolution.
SOURCE: Needing Ethernet Controller for Aspire T690
Let me first say that going with XP Pro and not vista is a wise choice. -- try DriverFiles.net
SOURCE: My Computer which is PC Desktop Acer Power FH,
upgrade the video..if its "on board" which is to say it is integrated onto the man board, you might still be able to purchase an expansion video card if you have the available slot for it. Be aware there are different kinds of slots(and corresponding cards)AGP,PCI,PCI-e so be sure you get the right one
Don't forget to rate the advice!
http://www.aa1consulting.com
SOURCE: how do you remove the cover of my acer aspire T690
un screw the nails or open the lock if you have one or press the side buttons and lift
SOURCE: vista was pre installed on my pc how do i install
A friend of mine had that problem. She contacted Acer and said she did not have a chance to make a backup disk and she needs to re-install the operating system. Within a few days Acer sent her the backup disks.
Just call Acer and ask for it, like she did. If that should not work for you, come back and someone will walk you through to put a copy of your drive on a cd. Hope things work out for you!
