Question about Crosley Cfw7500kb,3.5 Cu.ft. Front-load Washing Machine
How do i get front door open when in lock mode
Posted by sheldonct on
twiddlers
    New Friend:
Switch off and if possible and run on rinse/spin cycle or spin cycle only then restart your selection as desired if you've enter the wrong cycle or see my solution to Samsung WF7604NAW posted on this site
Posted on Oct 14, 2012
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
Hi, My 2013 Toyota RAV4 front passenger door lock is caught. It sounds like it locks/unlocks- but we can't get it open-seems caught. How can we fix this? We don't use keys, always have fobs in our poc
SO DOES THE METAL KEY WORK OR NOT?
If the electonics magic fails , this is first., right?
just passenger door?
so locks can jam, and can be very hard to fix.
object stuck there, (closing door with junk in hands)
also playing with latch, by kids can trip it into an illegal mode.
first get it closed, 100% is it.
then use the key, if that don\'t work it needs service.
the key is for emerancies, say baby stuck in car, so..... use it.
Dec 20, 2014 | 2013 Toyota RAV4
Samsung VRT with a DS or D5 code? Door closes but won't lock
bad door lock switch mechinism or the control board is bad at the emergency door lock circuit? where the wires from the door swtich attache, check ur schematic and will need a multimeter
Dec 18, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
My duet ffront load washer give me the error code dl then an f when I try to start the cycle. I have tried pause cancel twice then opening the door and starting the cyle and closing the door last thing...
The door is not locked after 6 trials then the Central Control Unit (CCU) will enters a failure mode and the digital display flashes FdL. This is a door lock failure and the only viable solution is the replacement of the door lock and switch assembly.
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening.
Gently peel the part of the door gasket near the door lock and switch assembly off the lip of the door opening outer lip. Remove enough of the door gasket to access the door lock and switch assembly behind the front panel.
Remove the three screws securing the door lock and switch assembly to the front panel and slightly lift then pull it back off the front panel and out of the out of the washer cabinet.
Connect the wiring harness to the new door lock and switch assembly one at a time then install it back in place behind the front panel.
Secure the door lock and switch assembly then put the eased part of the door gasket back over the outer lip of the door opening. Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Cant get my 99 xj8 out of valet mode, and my trunk will not open.
There are Valet keys (often with a green knob) that will
only unlock the front doors and the ignition but not the
glove box nor boot/trunk.
When either the front door locks or the console button is
pressed, all the doors should lock. Likewise, when either
front door is unlocked, all the doors fuel filler lid and if
selected, the boot will also unlock.
Boot lock has three positions. Unlocked to the left,
automatic with the doors in the center, always locked to the
right. Simply remove the key in what ever position you desire.
The locks can get confused and not work correctly. Simply
sit in the car and manually lock all the doors. That will
usually get the locking module sane again.
Feb 28, 2010 | 1999 Jaguar XJ
I have a Frigidaire LTF2140ES3 washing machine. No matter what I select, I hear the door lock click, and then random clicking as it tries to go through the modes, but nothing happens.
sound like you need a door lock. your door lock is not locking or not tell the control that it is locked.. should try 6 times to lock before it will give up trying... hope it helps
Sep 18, 2009 | Frigidaire ATF6000ES Front Load Washer
My washer is stuck in pause mode and when I checked an the error it was E41 code
E41 Control board thinks the door switch is open. Remove the door lock assembly and measure the resistance of the PTC. Shortedor open.Defective door lock assembly. Around 1500 Ohms. Defective control board.
Hotpoint wm63 door locked
The door lock has failed in the locked mode, only way to open door is to force it open.
Remove top cover, screws at rear , slide cover back away from you.
Down at the front right side you will see the lock, it is reddish brown in colour, with 3 wires attached.
Force a long handled screwdriver or similar between lock and cabinet front, and force the lock, you may have to break it, but it does not matter as it is faulty anyway.. The door will then open.
Remove the 2 screws holding the rest of the lock , and pull up with wires still attached, .
Transfer wires to new lock on the same connectios, and refit.
Test it, if it still does not work then you may have to fit a new door latch and or spring.
Plz rate this solution and if you have any further probs, plz let me know.
Dec 20, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Crosley Cfw7500kb,3.5 Cu.ft. Front-load Washing Machine Logo
134 people viewed this question
Top Crosley Washing Machines Experts
peter gittos
peter gittos
Michael Thomas
Michael Thomas
Lawrence Oravetz
Are you a Crosley Washing Machine Expert? Answer questions, earn points and help others
