Question about HP Pavilion DV9727CL Notebook
Have a hp pavilion dv9727cl laptop,when I try to power up all I get is blue light on and off. If I remove the ac plug and battery, then remove the cmos battery and push on power button, then put cmos
When I try to power up all I get is blue lights on and off. If I remove the ac plug and battery, then remove the cmos battery and push on power button, then put cmos battery in and battery or power plug and start it, starts up and works fine till it shuts down or restarts then I have to do the same proceedure to get it started again. what would cause this?
Posted by Dennis Harb on
Claudiu Rascol
    Sergeant:
  • HP Expert
  • 427 Answers
Use new battery. Post results
Posted on Apr 18, 2013
5 Related Answers
ebenezer
Ebenezer Phillips
  • 25 Answers
SOURCE: nc6320 Laptop power
hello the first thing to make sure of is that the ac adaptor cable is not having any partial contacts ofany kind whereby power gets into the laptop irregularly.this could have adverse effect on the circuitry. it is not enough just checking the output of the ac adapter by a meter.try straighten the cable from the adapter and check the meter for voltage fluctuations. if the above is okay then the problem could be on board leve.
Posted on Aug 11, 2007
Anonymous
  • 50 Answers
SOURCE: HP ZD 8215 Laptop Start-up Problem.
2 beeps with no post means either you have a memory failure or the motherboard has failed
Posted on Jul 17, 2008
Anonymous
SOURCE: hp dv9000 will not start up. blue lights are go
you get a black screen right, nothing at all then no bios, no logo, nothing at all?
Do you get any beep codes and if so in what order?
did you try different ram?
First try to plug your laptop to an external monitor. If it works, you screen is bad, if it doesn't you probably need a new motherboard.
Posted on Dec 23, 2008
Anonymous
  • 52 Answers
SOURCE: HP Pavilion 8000 power light and battery light blinking
hi,
Hp recalls some king of batterys, maybe yours it is on this recall, contact hp web or phone to take advantege of this recall, otherwise appears that your battery do not work you may replace it.
Thanks
vcrtech
Posted on Apr 27, 2009
Norman Al-Anbar
  • 630 Answers
SOURCE: hp dv9700 doesn not start
try safemode if not check F2 for mem.
Posted on Sep 08, 2009
My laptop pavilion dv7 window 7 core i5 stops starting on fir any reason and when I plug it on ac there is a blue which appears and if I press the power button this light becomes orange and the laptop does...
I take it is the HP Pavilion
try to charge the laptop for a couple of hours without switching it on, it might be the battery is completely drained.
the light will change to orange to let you know it is charging, when fully charged it should change to blue and stay blue until you remove charger. you should try to use the your laptop with the charger adapter connected at all times when it easy to do so. I do hope this helps.
Sep 20, 2013 | Computers & Internet
My laptop is a hp 6365 and it was working last night but then when I got home it would not turn on. When I plug it in the blue light on the charger lights up but no other lights(The lights the show that...
1. Unplug your computer and remove the battery.
2. Press the power button several times.
3. Reattach the battery, plug in the computer, and press the power button.
4. If the problem persists, look closely at the screen. If you can make out faint, dim images, the backlighting components must be replaced or repaired. If not, it is likely another issue with the physical hardware of the machine such as the screen or the motherboard.
Mar 05, 2011 | HP Hewlett Packard Pavilion dv6365us PC...
Will not power up. Blue light around inserted AC is on.
Take out the battery and plug it in. If that does not work then the AC jack on your laptop is no good, either that or the power supply inside the computer. You mentioned the blue light, is that on the cord or on the computer?
Mar 13, 2010 | HP Pavilion dv9000z Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
Hello. when i plug in my hp dv5220us laptop it sounds like the fans running all cenyer lights on but power button will not turn on. same with battery
Remove the AC power jack and then the battery. Hold down the on/off button for 30 seconds, that will drain any residual power from the laptop.
Then just plug in AC power only and try to boot the laptop up. If it boots let it load Windows and then shut it down. Remove the AC power jack and then re-insert the battery. Then try to boot the laptop up.
If it boots up you all good.
If this does not work please post back.
Good luck.
Nov 16, 2009 | HP Pavilion Dv5220us Notebook
HP Pavilion dv9700t battery dead, faint blue flash from plug
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 18, 2009 | HP Pavilion dv2700t 2.5GHz Intel Core 2...
My hp pavilion dv2500 will not turn on at all. I can plug up the ac adapter and the blue light surrounding it comes on but it will not come on when I push the power button.
A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective.
Another possibility would be that there is a short circuit somewhere in the power circuitry on the motherboard.
Sep 20, 2009 | HP Pavilion dv2500t Notebook
Hp dv9000 gets power (blue lights) but won't turn on
Remove the plug and battery for afew seconds then try again.
Mar 12, 2009 | HP Pavilion dv9000z Notebook
HP Pavilion zd8000 don't startup
have you even try to remove the battery in your laptop?
if not try to remove it in a miniute then put it back again.
maybe it is in standby mode.
Jan 23, 2009 | HP Pavilion zd8000 Notebook
ZD7000 Lights, no fans, power switch not working.............
Dismantled notebook thinking compressed air removed component or connection. Nothing. Reassembled most of notebook. Left battery and power disconnected for 6.5 hours, I later plugged only AC power into unit. Fans started spinning. Completed assemble of notebook and installed the battery. Blue lights returned. Problem seems to be the battery. Shorts out something and needs about 6 hours drain out. Works great now without battery, using AC power only. Ordered new battery.....
Feb 06, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
HP Pavilion DV9727CL Notebook Logo
225 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
