Sharp R-1870 Convection/Microwave Oven Logo
david shaffer Posted on Oct 14, 2012
Sharp micro counts down 59 seconds and stops - Sharp R-1870 Convection/Microwave Oven
  • HotCap Jan 27, 2015
    I bought a Sharp Microwave Oven with Sensor, Grill and Convention functions, R-967(SL)M, a few years ago in London, United Kingdom. Problem: Now, each time the timer counts down to 1 second (for example, 1 sec. or 2 mins. 1 sec. or XX mins 1 sec.), the heating function just stop as long as the timer shows 1 second. In addition, I relocated to Hong Kong and the local Sharp customer service refused to provide any repair service (even if paying!) since I did not buy the product model in Hong Kong! The warranty period has ended, hence there is not an issue with warranty service. Appreciate if any expert(s) out there could kindly provide assistance or at least offer a direction/suggestion which I could pursue to get the appliance back to working again. Thank you!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 09, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
799
Points
It seems this has been happening over the last few years. I am a retired appliance tech. My 1870 also started the 59 second routine, Also in a motor home. Pure logic. Had to be the board. New board same results. So now I need to run down a parts manual and possibly service manual, and get the damper switch and motor refered to in earlier posts. Changing out the board was fairly simple. Dropping the unit to change out the other components sounds like it will be a tad bit more difficult.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 18, 2010
SOURCE: My Sharp micro will stay on for 59 seconds and
This is not a problem on the board, it is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded them to our site here and here.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 27, 2008
SOURCE: Our sharp 957 will now
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
This is also likely why your convection mode stopped working.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Anonymous
  • Posted on Jul 08, 2009
SOURCE: Sharp R-1874 shuts off after 59 seconds
I had the same problem. Turned out to be the micro switch and damper motor. I replaced both myself and fixed the problem for less than $40.00. The best advice I got was replace the switch, reconnect the motor and make sure the motor runs through a damper door cycle. It didn't run, even though it showed continuity and had power, so I replaced the motor which solved the problem. The micro switch which is activated by the cam on the damper motor has to be cycled within one minute, or the unit shuts itself off. The damper motor on my model R-1870 is found in the right rear section of the assembly when facing it. You have to remove the unit, and remove the outer casing to get to it. The damper is a simple sheet metal door, activated by the motor, and the switch mounts at the top of the motor and is activated by the same cam that activates the door.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Jan 29, 2009
SOURCE: Sharp model R-1870 Carosel quits cooking at 59 seconds
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you. You will need the free Adobe Reader to view or print it.
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: Sharp R-1870 stops at 59 seconds
Wow. I just read something ridiculous!
Well, never mind that, here's your solution:
This is a common problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
Sharp microwave r1870 only runs for 59 seconds
If it consistently runs for exactly 59 seconds, and shuts off, it's probably the control panel.
If it runs approximately that length of time, you might have a defective thermal protector on the magnetron, or the magnetron is running too warm for some reason.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
My Sharp R-975 Microwave after settin the timer and starting only runs for 59 seconds and stops, I can press start again and it goes for another 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
I'm not sure this is a US model or if parts are still available, so look up Sharp in your country.
10helpful
My Sharp micro will stay on for 59 seconds and shut off no matter how long the timmer is set. Sharp model r 1870 It does this every time it is used . The control board has been replaced.
Sharp r96st stops at 1 sec and halts whilst preheating oven
Our sharp 957 will now only microwave for 59 seconds then stops and rattles for thirty seconds. The convection option stopped working ages ago. Any ideas please?
3helpful
59 SEC NEED TO GET FRONT OFF MICRO
If your unit runs for 59 seconds then stops, the problem is the convection damper motor. (Sharp part # RMOTDA222WREZ).
Unfortunately, you cannot access this from the front - the whole unit has to come down as the entire outside cover has to be removed.
This is a pretty major job and the motor (located below and behind the magnetron tube) is rather hard to remove and get back into place. This is probably better left to an experienced technician. You can call Sharp 1-800-BE SHARP for a referral to an authorized servicer.
Will shut off in all modes after 59 seconds. will keep countdown time when shuts off, restart and will start and continue count down time for another 59 sec only. voltage good. unpluged repluged. makes no...
See the attached sample photo.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We even have a video on our site that shows you how to safely & easily remove the control panel assembly to send it for service.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here or here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Top Sharp Microwave Ovens Experts
ZJ Limited
ZJ Limited
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
