Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
Sam Stambrowski Posted on Oct 14, 2012
Hi,may name is Sam. I have sony tv KDL-52VL150 120V-60HZ-300W LCD. The picture on my tv is darker,objects move like in slow motion and the middle part of the screen from up to down about 20inch line is darker then the rest of the picture. Please help.Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Oct 15, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
11451
Points
53
This could be a defective panel --is it like this on all inputs
5 Related Answers
Ron F
  • 135 Answers
  • Posted on Nov 10, 2008
SOURCE: Sony Bravia KDL 40S20L1
You should have a 1 year warranty from Sony. Call them before it expires. This is probably a LCD panel issue.
jerryg50
Jerry Greenberg
  • 1691 Answers
  • Posted on Aug 06, 2009
SOURCE: SONY KDL-52xbr4 - lcd panel shot after 17 months
This can be the panel itself, and or the matrix decoder/driver boards. The cost of this type of repair can approach the cost of a new set. From your description, I am thinking it is the panel itself that has failed.
Parts for your set are from Sony only because there is no third party manufacturing for these types of parts and assemblies.
Usually, when these types of sets become defective they are usually not worth servicing. During warranty the manufactures generally give a new set to the client, or they give a re-built set which has been built up using parts and modules from other sets that came back for service and had different types of problems.
If you know a tech is is good at servicing these types of set, maybe he can find a number of scrapper set of the same model to take parts from. You just have to hope the ones he finds have the same types of fault.
Jerry G.
Anonymous
  • 3153 Answers
  • Posted on Aug 10, 2009
SOURCE: Airsoft gun hit Sony Bravia LCD screen, can this be repaired??
Yes but not cheaply
Anonymous
  • Posted on Nov 24, 2009
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
Anonymous
  • Posted on Aug 05, 2010
SOURCE: sony bravia kdl 46s4100 no picture
it sounds like your back light might be going out. You might be able to fix this by installing a new backlight inverter board.
My Sony KDL-32M3000 has ghost (dark red) display with slow motion picture. What could be the cause and how can it be repaired. Thanks
Thats usually caused by bad flex tab bonds on the LCD panel itself. If you search for flex tab issues vidoes it will show how the pisture can get slow motion in areass as well as double images in that area.
2helpful
KDL-40XBR5 has vertical color lines no picture .After 50 minutes picture shows back with right side darker. TV was purchase 2008
It sounds like you might have a defective LCD panel. Your warranty for your TV is 18 months. Some of these models the warranty was mis-printed and said only 12 months.
4helpful
2answers
Sony KDL-46XBR4 right 2/3rds screen darker, motion blurred
Hi Ron, thanks for describe many valuable details. You suspect something wrong with the fluorescent tube, if it is true, shall be dark on top or bottom, not left or right, also the problem with the backlight the TV will shut off and the timer LED will blink 6 times.
I think there is the bad connection inside the panel or the t-con board, only think you can do is try to reconnect the wires under the aluminum foil (see the picture) or replace the panel.
3helpful
Sony KDL-46XBR4 much darker on the right side of screen
ITS THE PANEL ASSY. I JUST HAD MY REPOACED. SONY WILL HONOR A COURTSEY WARRANTY UNTIL 2012
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
