SOURCE: SCRATCHY SOUND
This could be a fault with the built-in microphone. One thing to try before condemning the camera is to plug in an external microphone and see if the noise disappears. Good luck
SOURCE: no playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
SOURCE: Only the audio is recording, NO VIDEO, onto the
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
SOURCE: I have a JVC camcorder
This is usually caused by an oxidized, misaligned or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician. My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs. If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
