I tried replacing the batteries and bending the metal where the batterie are inserted. Tried to reboot by depressing the joystick + page + power on buttons.
I've got a 130 that was over volted by accident. I presume the internal fuse was blown and took it apart, but it isn't apparent where the presumably tiny surface mount fuse is located. Anybody able to point me in the right direction?
SOURCE: Garmin Rino 130 no Power
There first 2 main thing to check..... the off on switch.... and the fuse. Insie the radio there is a very small fuse.... its a surface mount component fuse... very small. That could be the problem. Also check the contacts on the radio..... if you have a way of connecting the correct voltage directly to the radios power terminals using jumpers I would definatly do it. Your most likly going to have to take the raio apart and and connect the battery to trace the power through it. The small fuse will be one of the first components after the positive power input. If this seems too much..... bring it to a radio shop... they can do all this quickly
SOURCE: Garmin 120 will not turn on
i talked with garmin tech today, he said to hold the button below talk, and the wheel and the power at the same time to master reset....it did not work for me but it might for someone else
SOURCE: RINO 120 :: screen blanks out with just a single horizontal line
Had to wait 24 hours to be able to post my own answer
By reading a number of forums, I've found that there was a WAAS satelitte update (bug), that causes this foul up.
The only solution I've been able to arrive at is DISABLE the WAAS feature, as no Garmin Update/patch (for Rino120) has been made available.
To shutoff the WAAS feature press your [Page] button until you arrive at the "Main Menu"
go down until your on the "Setup"(hammer)
go in (by pressing in, on the directional button)
go down until your on the "System"(gears)
go down until your on WAAS, go in and select the Disabled
go up to the "X" (top right) press it, then you can [Page] button anywhere you want from there.
Wonder what WAAS is?
http://www8.garmin.com/aboutGPS/waas.html
Take care.
PS- Garmin if you read this....I would like to have my WAAS back, and since I registered for updates, back in 2005, why didn't I get an email from you telling me about this issue (when it happened and provide a solution - at the same time :: even a work around as I've posted here)
SOURCE: Rino 120 - Disabled WAAS
Have you upgraded from Software version 3.2? Version 3.3 addresses a memory overflow problem when receiving two or more WAAS satellites.
SOURCE: Garmin Rino 130 Shut Down
I had the same problem; mine would shut off when bounced around too.
I used a #0 phillips screwdriver (very small) to take out the 6 screws that hold the case together, Carefully separate the face and back because there are wires that can be broken if you pull them apart too fast.
After you get the case apart, lift up the circuit board at the bottom and you will see a small blade pin that sticks out from the side where the batteries are and is supposed to slide up into a contact on the circuit board. I guess over time it starts to wiggle and get loose so I carefully bent the pin (very slightly so it would rub the inside of the contact.
So far I have tested it by dropping and beating it up a little and it seems to have fixed the problem.
Hope this helps.
