Question about Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Pip module location in 57h82 - Toshiba 42H82 42" Rear Projection HDTV-Ready Television
Posted by Tullio Tenaglia on
Tom Russo
    New Friend:
  • 30 Answers
Issue is most likley on hyper board
Posted on Oct 16, 2012
1helpful
This is jeff I just received an answer to my problem with my Toshiba 57H82 57 in. Rear Projection HDTV. The answer was " Try Wathing the Picture in Picture " But I don't know what Wathing Means
srry . watch the picture in picture . the sub video path takes a different route through video processing and may look ok. the pip control button should be at the bottom of the toshiba remote.
2answers
Toshiba 57H82- Distortions on the picture screen
You have leky caps in your regulated power
supply they are typ 220 uf 200v and are large
and round next to flyback
Projection set- 57h82 - need plug location for signal board hookup from control panel on front,and av jack panel,and hookup for if module standing up
FRONT PANEL HOOK UP IS EITHER TO IR PICKUP BOARD ON THE TOP OF THE BLOCK BY THE CRT LENSES OR ON THE FRONT OF THE SIGNAL BOARD.
Toshiba 57H82 problems
Val,
It's sent via Pando and you should get a link to it in your mail. To open it you'll need Pando, it's a free download if you don't already have it... The hyper module on that has about 10 caps that are common in that failure. If you need anything off board don't hesitate to ask.
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
57H82
We rebuild them for $175.00 out of the Tv - which includes shipping back to you...
Or you could try PTS Elctronics $200.00 plus shipping..
PO Box 442
360-642-4993
2answers
Service Manual for a Toshiba 57H82
i hook up the cable for cable tv to my tv but it only works in the pip and when i try to change it to the full screen all i get is snow .and it wont show the picture at all untuill i change it back to the pip
What is the PiP module and where is it located?
The PIP module is a board that allows you to view two different pictures on your set . Also if your having a convergence problem you might want to suspect an opened fuse that supplys the voltage or possible opened resistors could be causing the problem that your still having . A volt-ohm meter would be helpful in finding your cause . Also be cafeful when checking any electrical device when power is active . Your problem is not your PIP module if your colors are not aligned . Good luck
2answers
Same Prolem with Toshiba 57H82 57
Just sent the manual via Pando - If you don't already have Pando you will need to download it first. It's a free download..
Bill
Hi i have a 93 Mitsubishi model# ck35402. I was told that the pip had went out. was hoping someone could walk me through on how to remove and reroute
From the bottom of the main board locate IC 2004 between the PIP module and the tuner. Remove the jumper between pins 2 & 6, then jump pins 6 & 7. Next , pull the pip module from its socket and toss it. The symptom for a bad PIP module could be black screen, no picture, blue streaks, wavy or jittering picture.The audio will not be affected. Make sure the symptom fits the cure before you bypass the PIP. Good luck!
Open Questions:
0answers
My samsung TV UN70NU6070FXZC can't turn on, the red light blink 2 times with dark screen and no sound, and this cycle repeated after about 20 seconds again and again. The Tv reboot again and again. Have to unplug power cord to stop it. Samsung Main board BN94-14106C, Power supply board BN44-01016A 1. Disconnect main board from power supply board: plug power cord, backlight on, output=13v ch1=120v ch2=80v ok. 2. Connect power board to main board disconnecting two connectors to screen, it can be turned on/off normally. No T-con board is found, is it included in the main board or side board? a. TV Standby: red light on, sound off, backlight off. on power board output=12v ch1=ch2=0v, on main board SW=0.1v PW=12vx2, HAVDD=AVDD=VGH=VGHD=0v FB_TRDY_3=0v. b. TV On: red light off, sound on, backlight on, on power board: output=13v ch1=124v ch2=82v, on main board: SW=3.3v PW=13vx2, HAVDD=AVDD=VGH=0v FB_TRDY_3=0v VGHD=0.1v. It seems that video part of the main board is not working? 3. Only connect anyone of the two screen connectors to main board connecting to power board, it can be turned on/off normally. a. TV Standby: red light on, sound off, backlight off, dark screen. on power board output=12v ch1=ch2=0v, on main board SW=0.1v PW=12vx2, HAVDD=AVDD=VGH=VGHD=0v FB_TRDY_3=0v. b. TV On: red light off, sound on, backlight on, dark screen. on power board: output=13v ch1=124v ch2=82v, on main board: SW=3.3v PW=13vx2, HAVDD=AVDD=VGH=0v FB_TRDY_3=0v VGHD=0.1v. It seems that video part of the main board is not working too? Maybe both of left-screen and right-screen be faulty? It seems not to be possible. It is same if only disconnect anyone of the four screen connectorsillustration tv . 4. Connect both of the two screen connectors to main board connecting to power board, it can't be turned on/off normally. Dark screen, red light&sound&backlight blink 2 times for 2 seconds then all off. on power board output=13-12v ch1=115-105-0v ch2=77-70-0vbacklight: lightness-a little lightness-dark, on main board SW=3.3-0.1v PW=13-12vx2, HAVDD=about 6-0v AVDD=about 10v-0v VGH=about 14v-0v VGHD=about 11-0v FB_TRDY_3=3.3v-0v It seems that video part of the main board is working now?. And then after 20 seconds the cycle repeats again and again!! I had to unplug power cord to stop it. I replaced the main board and power board, nothing changed.
See all Toshiba 42H82 42" Rear Projection HDTV-Ready Questions
Toshiba 42H82 42" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
 Grubhead
Grubhead
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
