SOURCE: cleaning the INSIDE of a rear projection tv - Panasonic PT-51G35
its better to see any experts near you,its risk your tv.
SOURCE: Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
SOURCE: Panasonic PT-53WX42 53 in. Rear Projection
Most of these Panasonic sets have a error code---unplug the set for a minute----plug it back in and turn it on---does the red power light blink in a sequence---3 blinks, a pause and three blinks?
If it is 3,3 that is short protection and usually means one of the two convergence chips is bad.
Let me know what you find and I will be happy to help.
Regards, SD TECH
SOURCE: I have a Green Dot Continuously in my Panasonic
that's most likely a dead pixel on the LCD display in the light engine, but can possibly also be dirt in the light path or on the optics. If the spot is kind of square it's most likely the LCD, and if it's more round or odd shaped, it's most likely dirt.
Good luck.
SOURCE: Describe your Panasonic PT-60LC14 60 in. Rear
here is a description of how to do it..
good luck..
Warning: Perform lamp time reset only when the
lamp has been replaced.
Be sure the power cord is plugged into a
properly grounded wall outlet. Then, press
the POWER button on the projection display
or the remote control to turn the unit on.
Lamp time reset procedure for TY-LA1000, TY-LA1500
While pressing the VOL - (volume down) button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
Lamp time reset procedure for TY-LA1001, TY-LA2006
While pressing the VOL - (volume down) button on the projection display, hold down the 0 button on the remote control at same time for more than 5 seconds.
For lamp part numbers TY-LA1000, TY-LA1001,
TY-LA1500, and TY-LA2006:
When reset procedure is complete, the screen on the left, or similar screen, will appear with the phrase LAMP TIME WAS RESET TO 0 (Most TVs).
Lamp time reset procedure for TY-LA2004, TY-LA2005
Press down both VOL - (volume down) button on the projection
display and MUTE button on the remote control at the same
time for 3 seconds.
When successful, the 2 LED’s on the front of the unit (Power and Lamp) will flash for 5 seconds.
If LED’s do not flash, repeat the procedure above.
