The light on our in-the-door ice and water dispenser was burned out when we moved in. I pulled the bulb, went to the hardware store and got a replacement bulb. When we went to install the new bulb, there was a "POP" and now the ice and water dispenser no longer works at all. The ice-maker does continue to work.
SOURCE: Ice maker
I had the same problem with the ice dispenser flap not closing properly, this cause very large build up of ice around the inside - get that sorted first.
SOURCE: hotpoint refrigerator water dispenser not working, while ice maker, works slower
Check or replace the water filter
SOURCE: GE GSH22SGRE - water dispenser not working but ice cube maker working fine
I just used the hair dryer and it worked the water is flowing again out of the dispenser
SOURCE: water dispenser not working but ice maker does
The water line freezes inside the freezer door. There is now an add-on water line heater you can install to thaw the line.
SOURCE: ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
