Question about Hansgrohe 06496 Croma Hand Held Shower - Slide Bar Mount Shower Accessory
Adjust hot water on hansgrohe metro shower - Hansgrohe 06496 Croma Hand Held Shower - Slide Bar Mount Shower Accessory
David Scarborough
    Scholar:
  • 72 Answers
The hand shower and wall bar does not control temp. The valve in the wall would control the temperature of the water going to the shower. I would need to be able to identify the model number of the valve in the wall to be able to give accurate instructions on temperature adjustment. If you need help identifying this valve feel free to give me a call at Hansgrohe 1-800-334-0455. Press 2 for tech and ask for David Scarborough
Posted on Oct 15, 2012
3 Related Answers
snap101
snap101
  • 117 Answers
SOURCE: The water coming out in the shower from a
pull the handle off and there is a black dial you can pull out and readjust on the shaft of the cartridge that will allow you to have cooler and hotter settings. it's black plastic and has little splines on it . the more you go one way the hotter it gets and the same the other way gets cooler
Posted on Jul 29, 2009
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: loss of pressure in Hansgrohe shower panel
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
HANSGROHE US
Phillip Heslep
  • 7 Answers
SOURCE: I replaced a broken Hansgrohe hand shower with a
Hi Christieb942,
When you get a new hand shower you can sometimes get sediment on the federally mandated FLOW RESTRICTOR. Not screaming, that is ****** in cheek. To CHECK the Flow Restrictor for debris, look at the hose connection end of the hand shower. You will see an INSERTED part that is green, yellow, or white. We have to push that in there to satisfy the EPA requirement for flow. You can pull it OUT and rinse it off. Then connect your handshower and try it and see if it is improved. You will not void the warranty in any way by doing this. I hope you understand what I am telling you, but if not you can call me 800-334-0455. I wish I could answer more directly, but Big Brother has eyes.
Posted on Sep 20, 2011
How do I adjust hot water safety on shower
Some mixer valves are slightly different. Can you post a picture of what you have?
Jan 23, 2015 | Hansgrohe Home
Adjust handle stop on Metro high arc
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
Clubmaster shower not holding temperature. Hot water not coming through.
There's only there things that are clubmaster, a shower head, and two hand held sprayers.
They all spray water, they don't heat water.
Did someone install a new part, the one that's behind the wall ?
If they did, most have a safety so people don't get burnt and they need to be adjusted.
Apr 16, 2013 | Hansgrohe Clubmaster Showerhead, Steel
Hansgrohe shower not hot enough
The first thing to do is identify the unit so I can give accurate instructions. Hansgrohe makes many valves and the temperature adjustment between them is different. Feel free to call me at Hansgrohe at 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'd be happy to help identify the unit and get you the instructions for the temperture adjustment.
Oct 05, 2012 | Hansgrohe Home
How do I remove cartridge part # 9273000 from my Hansgrohe kitchen faucet?
Please contact us at the below number or email me directly and I will get you a copy of the instructions that you need.
Regards
Chris
Christopher Scott
Technical Support Specialist
Hansgrohe Inc.
1492 Bluegrass Lakes Parkway
Alpharetta,Ga 30004
Tel:1-800-334-0455
Fax:678-762-7042
Email:[email protected]
Feb 19, 2011 | Hansgrohe 06649860 Solaris Single Hole...
Hansgrohe 06358620 shower not hot enough
Remove the handle by loosening the screw near the bottom. You should see a plastic ring, probably green, that is the hot water safety. Adjust it so that the handle will turn further for more hot water. It most likely pulls out, then turn it left, reinsert and reattach the handle.
Apr 26, 2010 | Hansgrohe 06358620 Pressure Balance Valve...
No hot water coming through the shower system, though hot water comes through the pipe without system attached
When you adjust the dial to mix the hot and cold for your desired liking, it goes into a mixing chamber before going to the shower head, im asumming your issue is within the mixing chamber.
Nov 05, 2009 | Hansgrohe Shower 26101 Pharo Prestige...
The water coming out in the shower from a Hansgrohe ThermoBalance I control is a little too hot on the coolest setting.When the center temperature control is turned to the clockwise stop position which...
Jul 17, 2009 | Hansgrohe Home
Insufficient hot water from Gledhill pulsacoil 2000
changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Feb 25, 2009 | Hansgrohe Axor Hansgrohe Starck Shower...
Hansgrohe 06496 Croma Hand Held Shower - Slide Bar Mount Shower Accessory Logo
272 people viewed this question
Top Hansgrohe Home Experts
ray gallant
Tom Chichester
Are you a Hansgrohe Home Expert? Answer questions, earn points and help others
