The picture is "pulled in" to the middle of the screen in a parabola, from both the top and bottom. Plus there are "ghosts" and the colors aren't right. It is this way for input both from our standard cable service and from the DVD player. It was fine last night when I went to bed; and messed up this morning from the first moment I turned it on.
SOURCE: sony kp 53h530 no picture or sound red light
he 6 blinks indicates the loss of 5 volts on the emitter of Q714 on the A Board. This 5 volts
is supplied from
the 5 volt regulator IC 2 (A Board) which receives 6 volts from the G Board.
It can be from alot of things better bring it to technical service its class A it heavy for do it your self :((( you can order the boards but they will cost alot
SOURCE: color distortion and arched picture
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: Sony HD Projection TV - Picture bent and seeing multiple colors
This is due to failure of convergence out ICs that need to be replaced in D board.
If you are comfortable with TV repair let me know to provide you technical info to fix TV.
SOURCE: colors don't line up, and screen is distorted on a sony KP43HT20
Problem #1) Convergence
Symptoms:
Problem #2 CRT Fluid has clouded over. Symtoms
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
SOURCE: Our Sony KP-46WT510 rear projection screen TV just
Convergence ICs, they are big black ICs will have part# on them if they are STK392-110s use 180s better ICs also CK pico fuses in front and behind ICs
they will look like resistors but will be Yellow or Green 5amps/6amp fuses
i have the same problem
I have the same problem. The picture is "pulled in" to the middle of the screen in a parabola, from both the top and bottom. And yes, there are "ghosts" in all three colors on the screen They cannot be fixed by using the focus button.
