2003 Nissan Altima Logo
Anonymous Posted on Oct 13, 2012
03 nissan altima high pitch whine from engine
Car just started making a high pitch dentist drill noise from engine compartment.
danoyachtcap
Level 3:
Top Expert:
  • Nissan Master 2,907 Answers
  • Posted on Mar 25, 2015
danoyachtcap
Nissan Master
Level 3:
Top Expert:
Answers
2907
Questions
Helped
1275203
Points
52081
Check the transmission oil level. That sometimes causes a whining sound.
Hope this helps.
TECHCALI
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 05, 2012
TECHCALI
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
Helped
4350
Points
14
I assume that you have a 6cyl engine, noise came from both worned secondary timing chain tenssioner shoes, just replace those two and while you have them all apart, also replace main tenssioner and guide, then all noises will go away. Good luck!
5 Related Answers
Anonymous
  • Posted on May 17, 2009
SOURCE: i have an 03 nissan altima engine makes loud clicking noise
1st check the the oil level and the vehicle's oil type.(owners manuel) 5w30-10w30
10w 30 is a thicker oil and could possibly be causing this.(Moves more freely through the engine heats the oil)
Anonymous
  • Posted on Jan 22, 2009
SOURCE: nissan altima 2005 noise from engine
i had the same issue had the alternator replaced and their is no longer a noise.
Anonymous
  • 232 Answers
  • Posted on May 06, 2009
SOURCE: High pitched electronic/dentist drill sound when accelerating.
Probably the front differential, your probably hearing the famous differential gear whine. Change the oil, put Lucas for gears in it. You can get a hand operated oil pump to **** it out through the dip stick if it has one. Then fill it with the recommended amount.
Anonymous
  • 3 Answers
  • Posted on Jun 23, 2009
SOURCE: high pitched squealing noise when i start engine
One of the belt should be loose or worn. Make sure they are not worn or cracking before tightening.
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Aug 06, 2009
SOURCE: High Pitch Noise(fuel pump?)
Do you hear it for a second when you just turn key to on & not start?
Rear end noise
Could be bad axle bearings if it is a "Woo, woo, woo" sound or bad differential if it is a high pitched whine sound.
1helpful
1999 Altima: My 1999 Nissan altima is making a loud whining noi...
you call it the serpentine belt, we call it the fanbelt.it,needs tightening,slightly loosen the alternator, then pull away from engine and tighten belt, tight enough when you can move longest part of the belt, between pulleys, 1/2 inch in/out.
if squeel re occurs fit new belt.
1helpful
I hear a high pitch sound in the engine compartment that starts when I start the car. With the car still in park, the noise does increase when I step on the accelerator. While driving the noise is in sync...
sounds like you need to replace the idler pully and maybe the tens. pully. and that will solve your sounds problem. whats happening is the bearings are bad and thats what you hear
3helpful
2answers
I have an 03 nissan altima engine makes loud clicking noise
1helpful
1helpful
3answers
High pitch whistling noise in engine compartment of 2005 envoy
There may be a small hole or cut in a vacum line or possibly just loose. Also make sure the air filter box and the big hose to it are secure and clamps etc are tight. Pulleys and belts can make a high pitch sound also.
3helpful
High pitch noise from engine compartment in 2003 Subaru Fores
There is a little beeper that sits just behind the front grill close to the Subaru emblem. It makes the sound you hear when you press the remote to lock or unlock the doors. It sometimes whines for a while but eventually stops. I have had this for a couple of years and it does not appear to have caused any problems.
Whining Noise when idle and gets louder when accelerating on 2000 Nissan Altima GLE
hi more than likley to be the alternator remove your fan belt start engine see if noise disapears yates210456
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Nissan Expert? Answer questions, earn points and help others
