How do I lift the gas hob on the A2 cooker. One of the red temp lights cables has come off when I was changing the bulb. Looks like I need to lift the lid to find it?
Remove cast iron pot stands and pull off all knobs and small timer buttons. lower the oven doors and look up under the panel holding the knobs and you'll see a screw at each end, remove them. you can now remove the stainless switch panel, (swing the bottom out first) you can now get access to screws at each top corner which should be removed. you can now lift the top panel of the cooker by about 5 inches when a pivoted stay should drop down each side to allow you to rest the top in an open position.
SOURCE: Smeg A2-2 no electricity...
check first that you have power to the appliance - open the cover over the connection box and check with a multimeter. also carefully check that the connection box is not burnt out. this is likely not a fault with the cooker but your power input
SOURCE: Smeg A2A all the Gas burners turn off intermittently
I think it`s got a regulator at the back where it connects to the gas.
Get it checked for the correct pressure.
SOURCE: I have a smeg A2-5 oven and have been told it
Well it is very easy.
First and all diconnect the power cord.
The element secured by two 1/4" screw in the oven.
you have to pull Range out and go, emove the back panel and remove the element wiring connector, and you are ready to replace it with the new one.
Should you need more details please feel free to contact me. I can provide you wiring diagram and instruction booklet.
[email protected]
SOURCE: how do i change the volume on the oven timer? i
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
