Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher Logo
Question about Electrolux 24 in. EDW5505EPS Stainless Steel Built-in Dishwasher
Wave touch electrolux error 01
Electrolux
  • Official Brand Answer
  • 4,342 Answers
Hi - Error code E01, typically indicates that a water leak has been detected under the tub. Unit may possibly need a hydraulic kit; however I would suggest contacting a professional to move forward accurately.
Posted on Oct 16, 2012
1 Related Answer
Anonymous
SOURCE: error code on electrolux dishwasher,
electrolux wave touch dishwasher giving error code 1?
Posted on Oct 20, 2009
2answers
Electrolux ewdw 6505error code "02"
Owners manual. Will be in the back. Google is your friend
I’m happy to assist further over the phone at https://www.6ya.com/expert/josh_8f8ad0a8f7e0e6d3
Electrolux EWDW6505GS error 01
Good Afternoon Friend,
I see that your Electrolux dishwasher, model# EWDW6505GS, is having trouble with an error 01. I suggest resetting your dishwasher. You will do this by either unplugging it or shutting the power off at your homes circuit breaker for 20-30 minutes. When the power is restored, run a wash. If your dishwasher is still experiencing an error 01, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Error code 1 Electrolux
I found that after 3 washes the flood well had enough water to activate the float switch thereby rendering the machine inoperable. What I done was drill a small hole in the plastic base well - the waster that drains out is minimal, not even noticed, but enough to keep the machine working.
Repairman didn't reset my error 3 code
Good Morning Suzanne, this is AP with Electrolux.
Thank you for submitting your question concerning your Electrolux dishwasher, EWDW6505GS. Typically an error 03 code indicates that there is a communication failure with the wash motor or wash motor hall sensor. Some tips for troubleshooting include checking for suds in the tub and check for syphoning or no fill conditions. If the error code persists, it would be advisable to have your authorized technician check the wiring between the main control board and motor since either part could need replacing. Hope this helps.
Electrolux E1DW6305GS0 error code 08
Hello ericsson1 - Typically error code E08 indicates that the control has detected a stuck or shorted key on user interface board. The wiring between main control board and user interface will need to be check by a certified professional. Depending on the diagnoses either part will need replacing. Contact a professional to move forward accurately.
1helpful
It says error 01
Error code 01
Leak Detected - When water is detected under washer
tub.
7helpful
Ewdw6505gso electrolux. error 1. have turned off
the water will have leaked into the drip pan underneath, which is installed to protect your floors. Unfortunately, only way to get at it is to pull out dishwasher and remove 3 phillips screws that hold it on. In order to repair leaks, Electrolux came out with a "leak kit", which is part number 154769101. Comes with all parts that they had leak issues with
4helpful
Check hose error on electrolux wave touch washing machine
I'm sure nojallo1 has already fixed his but I just ran into the same problem and didn't find anything in my searches for a solution. The problem I had was the test cycle wasn't long enough to get hot water through my water lines so it could verify the hot and cold hoses were in the proper places. Solution: Turn the hot water on in all the sinks in your house until they have hot water running through them. This will prime your hot water line so it is full of hot water instead of cold water. Then run the install cycle again and it should be fine.
24helpful
5answers
Top Electrolux Dishwashers Experts
Mike
W.L.
mark warfield
mark warfield
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
