R/front turn signal doesn't work checked everything has power, chk connections, bulb is there any fuses that control this, 2006 ford fusion se model
Http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f8075c761#hd1-1-6 Here's the wiring diagram,replace bulb and see if that helps.You never know.
SOURCE: Replacing front turn signal bulb on 2006 Cadillac SRX
wow i feel sorry for you because Cadillac designed this bulb to be a don't get to bulb but OK here's what you do take the bottom cover off or skid plastic panel under neath the front end theirs little plastic clips holding it on just get come dikes and don't cut them but just use it to help pull them out. after you get that off use a flash light and locate your light housing you should see two screws holding the house in i think those screws are 8mm i cant remember remove those two screws and be careful the metal from the bumper cuts you pull the light housing out and remove all the screws around the housing and open the housing up replace the bulb and make sure your contact to the bulbs clean and then reassemble the way you took apart. if you cant get it well then best bet is take it somewhere i know Cadillac charges an arm and a leg so you can go somewhere else.
SOURCE: My turn signals on my
Replace the flasher unit, it is usually located on or near the fuse box, if this fails it will disable the turn signals.
Hope this helps
Ed
SOURCE: 2001 Toyota Tacoma- turn lights not working and cruise control
fuses???
Check relays.....
Harness grounds, engine ground,
Check the trailer harnes for short.
Vitally
SOURCE: Left turn signal
Well, seeing that you have a multimeter, check power at the socket and make sure it has power there. If there isn't then your wiring has an issue somewhere.
