Optical block
SOURCE: optical block
the optical assy is a large amount of work i wouldnt recomend doing it yorslf at all. please leave that to the pros. you have to completely disassemble the tv from the back. i can do it myself in about 45 min.
SOURCE: What does a bad optical block cost to repair on a
Call UED for price of rebuilt one 1-800-648-6657 Light Engine
SOURCE: have a sony kdsr60xbr1, has a yellow tint to it...
Did you try looking in their website? http://sony.ca/view/Television_Bulletins.htm
If you are not satisified check out this website and you might understand the problem better. There was a Class Action lawsuit regarding this model
http://sites.google.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock#TOC-Summary-of-Sony-warranty-extensions
SOURCE: how do I change the optical block in a sony tv
Disconnecting wiring from power supply block
This step
may be optional, if power supply block must be transferred to purchased
replacement optical block. Undo the blue plastic-coated wire holders to
release the two wire bundles. Disconnect the connectors shown with the
dotted lines in the photo below. One, which presumably provides power,
is disconnected directly from the power supply block, and the other is
a regular wire connector.
Disconnecting the optical block fan wires
Disconnect the optical block fan wire connector:
Disconnecting the wiring from the optical block circuit board (C Board)
Carefully pull up on the three wire connectors directly connected to the top of the C Board:
Final wire disconnection from C Board
Remove the screw and gently pull the blue ribbon ribbon cable out of the side of the C Board:
Your optical block should now be entirely free of the TV and ready to
ship. I recommend adding specific protection for the projection lens,
then sealing the whole unit in a bag to prevent infiltration of dust or
packing materials, then carefully packaging it with substantial padding.
Removing the projection lamp (in cases where you are installing a purchased replacement optical block)
Loosen the hex screw next to the projection lamp housing, and pull the lamp and housing outward from the metal clips.
Picture of replacement optical block for KF-60WE610 (courtesy John Setar)
Here
is a picture of a replacement optical block for the KF-60WE610. Note
that some parts of the old optical block need to be removed and
installed on the replacement block.
