Wonderful.
Share a website with you ,
( http://www.wholesalemkt.net/ )
Believe you will love it.
We accept any form of payment.
Communication problem. Check the wiring between the Main Control Board and the Speed Control Board. Wiring bad, correct wiring problem. Wiring good, replace the Main Control Board. If the problem is not corrected, replace the Speed Control Board. Here is the part you need.
SOURCE: my bosch wfk2401 front loader is stuck on spin
Hi
There is a door bottom right of the system which has a screw out (by hand) plug.
Remove this and ensure there are no foreign objects such as coins, bobby pins etc stuck.
I have found this to be a problem with the Bosch systems and cost me $150 the first time.
Ensure you have some towels as when you open the plug, water will escape
Mark
SOURCE: getting nf code on final spin cycle
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Hello - Typically error code E9F indicates a communication problem. A certified technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnostic either the wiring, main control board or speed control board would need to be replaced. Contact a professional to move forward accurately.
motor has been replaced as well as main pcb at bottom of machine, unit worked ok once during test then repeated same fault, putting unit on spin cycle it goes into drain 3-4 times then the start pause button flashes, if any other buttons depressed then E9Fcode comes up on display.
the spin indicater led display rotates as if motor spinning but as mentioned earlier only drains 3-4 times then stops alltogether and start/pause light flashes
Check all the wiring for any signs of wear and corrosion and be sure to check that all plugs are seated.
thanks for the info, baut sadly nothing found wrong with wiring. ill try replacing display pcb and door switch/lock assy
Keep me posted.
