Sometimes when driving it will just stop running without any warning. i usually have to wait anywhere from 5mins to a hour...then it runs fine for a little while. then problem repeats itself. very dangerous. I have had the fuel pump checked. They said that it is working fine.
SOURCE: 1995 Jeep Wrangler 2.5L Fuel Pump/Check engine light
Could be one of several items...I'd check the fuel pump relay, auto shutdown relay and the ignition switch itself. I'd bet on it being one of those relays but, we all have been fooled at least once!!! I'd also make sure that body and engine grounding is good and clean. Relays can't work properly without a good ground.
SOURCE: 2002 Jeep Wrangler 4.0 When Driving the Engine Dies
Put the key in the ignition and turn it on and off (3) times without starting the jeep, leaving it in the on position count the (1) flashing indicator Light, Eg: (5) flashes, Then there will be a pause, then it may flash (3) times, this is a code #53. Keep your Eye on them and write them down. If you should miss (1) Repeat as many times as needed, Info: A #55 means there are no codes!!
SOURCE: I've owned two 1997 Jeep Wranglers and eventually
This is a broad spectrum of possibilities. I would first start with a simple approach of insuring good gas.
When these symptoms occur, get a bottle of fuel additive and add to your tank. Possibly you have some condensation issues. This could be just the ticket... I hope so. Good luck.
SOURCE: my 92 jeep wranglers windshield wipers stopped working
the wiper needs to be tighten some more, there is a nut that holds the wiper to the motor tight that nut.
SOURCE: 1994 jeep wrangler 6 cyl 5 spd no start
have u ck out the ignition switch [not the key & tumblers],, or the neutral safety switch to see if u have power ,,also seen broken wire at solenoid on starter too,,hope it helped,,
