SOURCE: i cant see anything on my vizio 32 inch television
Put off the TV Using the remote .Then unplug the TV 's power line from power source.Allow this for Just Over one minute .Then plug back the powerline and your TV should be okay.
SOURCE: Vizio VX32L No Display and Can't Power Off
Old messages and bcipollina is gonna get to read this resonse twice; sorry-
If it just fails to turn on or ignores the remote, the
main power supply is probably at
fault and without some technical background and a couple of test instruments,
you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it
stand overnight or at least several hours, remove the back panel and look for a
separate board with mostly larger components on it; it will have a ferrite core
transformer on it and several larger capacitors which are cylindrical and
mounted vertically to the board.
Before touching anything inside,
especially on that board, allow several hours to be safe since the larger
capacitors can hold a painful voltage charge for some hours.
If you see signs of overheating
such as discoloration of the board material, it may not be repairable but if
you can find a part number on the board, you might be able to buy the power
supply and install it yourself.
If there are no signs of heat
damage to the board, there may be companies offering to repair it as a
subassembly instead of repairing the whole set which could be much more
expensive.
If you choose to replace or have it done, the power supply still may not be at fault since most
are capable of switching on and off if a downstream problem is causing an
overload.
BTW, from what I have read about Vizio, I think they are close relatives to iLo which was also sold by Wal-Mart.
Quality control anyone?
SOURCE: my vizio vx32l will not turn on. vizio logo will
The main board has failed. Replace the main board will fix the problem.
By the way, where did you buy the TV? If you have bought it from Costco then try to give them a call to see if it still under warranty.
Hope this will help.
SOURCE: NO RGB SIGNAL - VIZIO HDTV TO LAPTOP
I've been online looking for a solution to this problem and couldn't find a fix until today. I just got off of the phone with a Vizio Tech. He told me that some pc's have a way for the monitor to show the screen externally, and that there's usually a button, sort of like the input option on your TV but its an output button for a laptop in my case. It should look like a picture of a TV in and out of each other. Mine was located on the number four key. I had plugged in my wires and put the TV input on RGB. then on my laptop pressed the function key and number 4 key at the same time and what do you know, I had a picture on my screen. I almost gave up on my vizio but love it even more now. I hope this helps.
SOURCE: my vizio vx32L turns on but only a black screen shows up
I had the same problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make
sure the backlight still works. I ordered a new "main PCB" from
tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine. I
used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272
2174 or it was 3632 0212 0150. Check your circuit and see if any of
those numbers match up.
