Hi, my Stoves double oven HAP0040,
Top oven section where i use the grill, i put the grill on and after about 10-15 misn the red light goes off at the frotn and the grill bars go off, (from red hot to back to normal)
When i use the oven the light stays on until hot enough then goes off when ready and for some reason the grill is getting to a certain temp then turning itself off.
Any ideas??
also im looking to get a user manual for my stoves double oven, where might i find one?
thanks
SOURCE: hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
SOURCE: Stoves 720ef grill not working
The grills appear to be independant of each other. Does the oven still work and the oven light come on?
Depending on your answer it could be that the Top Oven Switch has gone faulty. The Grill Regulator and the Switch work together on the top oven. To get at both you will need to take the top of the oven off.
SOURCE: Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
SOURCE: stoves oven
check for 110 volts at the igniter if you do have it then change the igniter... whirlpoolpartssurplus.com
