Question about Broderbund PrintMaster® Platinum 17 Full Version for PC
Install printmaster 17 in windows 7 - Broderbund PrintMaster® Platinum 17 Full Version for PC
4 Related Answers
Anonymous
  • 581 Answers
SOURCE: is there a manual with the Printmaster 17?
you can download the manual from my website
http://tricia8765.fatcow.com/COMPUTERTRAINING%20MANUALS.htm
you will see it is around the fourth entry on the link
Posted on Jan 17, 2010
yaoyang
  • 2340 Answers
SOURCE: Is there a patch to have Printmaster Platinum 17
There is no patch/update available from Broderbund, to make PrintMaster® Platinum 17 Full Version compatible Win7.
Posted on Oct 27, 2010
Testimonial: "Thanks for the quick response! Not the answer I was hoping for but I appreciate the answer."
mariolands
mariolands
  • 2296 Answers
SOURCE: Trying to install Printmaster 15 for Windows 7.
Apparently no, it does support only Windows 98 / NT 4 / Me / XP. However, here is a thing you can try if a program cannot be run under Windows 7 because of compatibility issues, which is the case with Print Master Platinum 15. You right click on the executable file that will install the application and click Properties. Select Compatibility tab and check Windows XP SP3. If it installs do the same for the EXE file that will run the application. You can find more about this Compatibility issue on Microsoft website: http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Posted on Dec 12, 2010
Amy Smith
SOURCE: Printmaster 17 does not save as pdf files under
Here's my solution: Don't waste your time and money on, use a program other than PrintMaster! PDF is universally accepted across formats/browsers/OS ...what kind of program would not export THE most commonly used format????
Posted on Sep 28, 2011
I have Printmaster Platinum 17 on my computer. It has stopped coming up and will not reload. Is there a site where I can download it again? Maybe directly from the internet?
Lest's star by telling you neither me nor FIXYA had ever released any version of Printmaster Platinum 17. OK? So, if you want to contact authors of this sofware, ENCORE SOFTWARE
Encore Official Site Download Top Software Hoyle Card Games The Print Shop...
Now, HAVING SAID THIS, dd you use ever Printmaster Platinum 17 with Windows 7? I understand that it is for Windows XP.
I'm no sure what kind of a mess you made with it uninstalling or removing but well, try to reinstall your original SETUP version in Windows XP COMPATIBLITY MODE
Befor you instal it cricght click setuo, select Properties, click on tab Comatibility and select option Windows XP Comatibility mode
If won'r work, I find no way to help you,
May 27, 2015 | Computers & Internet
I am running windows 7 and I would like to know how to install an old version of printmaster silver 10 on windows 7
Printmaster 10 may not work with Windows 7. Just uninstall Printmaster 2012 then install Printermaster 10 using the installation CD.
I recommend you go to the Printmaster support site and ask them if version 10 will work with Windows 7 so you do not have to uninstall 2012 version if version 10 will not work with Windows 7.
Oct 15, 2012 | Dell Inspiron 1720 Notebook
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
Can't install PrintMaster Platinum 16 on my Windows 7 PC
This version of print master is not compatible with windows 7.
see the compatibility criteria of Printmaster on the link given below!
http://www.microsoft.com/Windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=PrintMaster%20Platinum&v=Encore&uid=18&l=en&pf=0&pi=9&c=Graphics%20%26%20Printing&sc=Image%20Editing&os=64-bit
You can try if this works in compatibility mode in your pc - Try running in compatibility mode. Right click the program icon, click Troubleshoot Compatibility, wait while the problem is detected. Click Troubleshoot program > select an appropriate version of Windows the program is known to run in, try Windows Vista SP2 > start the program to see if it runs. If it runs, click next to proceed with saving the settings for it.
Mar 19, 2011 | Encore PrintMaster 17 Gold for PC
Is there a patch to have Printmaster Platinum 17 work on Windows 7
Oct 27, 2010 | Broderbund PrintMaster® Platinum 17 Full...
Will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
Dec 15, 2009 | Broderbund PrintMaster® Platinum 17 Full...
Just got Windows 7 and trying to install printmaster gold 17...won't work. what do i do?
Windows 7 has a compatibility wizard that you can use to help install it. Go to start, control panel, and then type in troubleshooter in the search box. Under programs, click "run programs for other versions of windows." Follow those instructions. If you need to browse to the setup file on the disc, do so. If that does not work, you can go to Broderbund's web site. They have a compatibility update for Gold 17 on their website. Unfortunately it is for Vista, but it still might help you with the compatibility issue
encore .
Nov 17, 2009 | Broderbund PrintMaster Gold 17 Full...
Broderbund PrintMaster® Platinum 17 Full Version for PC Logo
71 people viewed this question
Top Broderbund Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
