*power cord
*power switch
but most likely it is the black switches on the fan shroud. These are the safety switches that prevent the vacuum from turning on.
Power switch faulty, slow speed terminal inside switch is burnt,hence
intermittent fault, hose uses second speed different lever inside switch
SOURCE: how to use air pump
Hi!
You need to take the power nozzle off and attach the thing that looks like a little plastic cup with two hooks on it. This is the intake guard. Attach it to the front. Now remove the cloth bag and put the hose on the hole where the bag was. You'll have to line the arrow on the hose up with the notch on the Kirby and push the hose arm toward the Kirby until it pops on. If you need to, lube up the edges of the hole with a wee bit of vaseline or hand lotion. This makes the hose engage easier.
SOURCE: how to use shampooer on Kirby Sentria Upright
Kirby shampoo manual with plenty of pictures HERE
Good Luck
Rocky
SOURCE: what attachments do you use to shampoo stairs with kirby sentria
This is what Kirby recommends HERE.
Rocky
SOURCE: I was vacuuming my car and the Kirby G4 just stopped
Greetings from GoVacuum,
Unfortunately there is no fuse on a Kirby Generation model. In my 10 years of repairing Kirby's as well as other vacuums I will tell you that 9 times out of 10, when a Kirby Generation doesn't turn on, it's the cord that needs to be replaced. This is by far the most common problem that we see on Kirby repairs.
The Kirby motor is very well built, and usually has a life of 30+ years (G3 is about 12-15 years now). The only other problem it could be on the Kirby would be carbon brushes, or the switch assembly.
I would first try testing the power cord, I think this will solve the problem for you. To test a cord on a Kirby Generation (all Generation models are the same machines, just different colors) first follow where the cord goes into the Kirby at the bottom. To access this cover easier, first remove the "boot" at the bottom of the outer bag. This is the plastic part at the bottom of the outer bag that connects onto the Kirby. You will see that there is a plastic cover over the cord. You will need to remove the screw that holds this cover on.
Now after you have removed the cover, pull the plug out of the machine. Once you have the cord disconnected from the machine, you can now test it to see if there is a short somewhere in the cord. You will need to purchase an inexpensive continuity tester from Home Depot, Radio Shack, or most other electronic stores. This will tell you if there is power running through the cord, or if the cord is bad. With the continuity tester, plug the cord into the wall outlet, then put the positive, and negative testing rods into the female end of the cord that plugs into the machine. You will then be able to tell if the cord has continuity going through it. The tester will indicate if there's continuity or not.
The picture here shows that the cord is good. If your tester does not light up, or indicate that there is continuity, you'll simply just need to purchase a new cord. As I stated earlier, this is the most common reason that a Kirby won't turn on.
If however your cord tests OK, this indicates that the machine either needs a new motor (or carbon brushes in the motor) or it needs a new switch.
Please feel free to email me if you'd like instructions on how to diagnosis the switch or carbon brushes, or if you need to purchase a cord for your G3. Also I can send you a parts diagram of the Kirby should you ever need any other part for it. I have all parts for Kirby in stock, and we are the cheapest price online.
If the cord tested ok, then there are a few other things that may have gone bad. I'd be more then happy to try and help you diagnosis the Kirby further. Please just request a repair clarifiaction here on Fixya with further details.
If this helped you figure out the problem, please rate my repair as helpful. I really do appreciate it, thank you.
Chris J.
SOURCE: Rug Beater isn't rotating during use
This defintiely sounds like your belt has broken or slipped off the motor pulley. The brushes on your vacuum are driven by a belt that attaches to the motor shaft on one end, and the roller brush on the other end.
If you really do have the Bissell 6594 model that you posted this repair under, then to check your belt, simply turn the vacuum upside down, and remove the four screws from the plate that covers the brushes. The bottom plate will then lift off, and you will have access to the brush and belt area of your machine.
You'll probably notice that the belt is either split completely, or is stretched out, and fallen off the motor shaft. Even if the belt is still completely circular, it may be a good idea to go ahead and replace the belt anyway. We recommend replacing the belt on your vacuum every 6 months even if they don't break, as they don't perform nearly as well when the machine has a fresh, tight belt on it.
The model 6594 uses the Bissell Style 7,9,10, etc. belt. It's the most popular Bissell belt on the market. If you don't already have a new belt handy, here's a link to your belt on our website if you need to purchase one:
Bissell Style 7/9/10/12/14/16 Upright Vacuum Cleaner Belts (2 Pack), Part Number 32074
Here's link to the Bissell Owners Manual for your model that will walk you through step by step how to replace the belt on your machine:
http://www.bissell.com/searchresults.aspx?searchtext=6594 &mode=userguides
I hope that this was helpful. If you have any further questions or concerns, please feel free to use the clarification request form here on Fixya, and I'll be happy to answer any of your follow up questions.
If this was helpful, please be so kind and rate the repair, or leave feedback, this is greatly appreciated by the Fixya community when a helpful answer is written.
Chris Jones
GoVacuum.com
