SOURCE: Samsung SCX-4521 "Paper Jam 2" won't clear
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
SOURCE: Fax problem
I had the same problem! You have to set your fax machine option to DRPD mode. Menu, to Fax setup, to DRPD mode, press ENTER, ENTER again, it should say waiting ring, you then have to call your fax line. Back to Fax Setup, Recieve Mode, press DRPD mode. This way your machine well distinguish a different ring for your fax.
SOURCE: Problems with Samsung SCX-4216F All-In-One Laser Printer?
SCX-4216F could receive fax, but didn't print out faxes. Can anybody help me with this?
SOURCE: how to set fax confirmation on Samsung SCX-4521F
Link to download manual for instructuions:
http://www.samsung.com/us/support/download/supportDown.do?group=printersmultifunction&group_cd=&type=printersmultifunction&type_cd=06010000&subtype=monochromelasermultifunctionprintersfaxes&subtype_cd=06010300&model_nm=SCX-4521F&dType=D&mType=&model_cd=SCX-4521F/XAA&menu=download&menuLink=/support/download/supportDown.do&prd_ia_cd=06010300&disp_nm=SCX-4521F&isEqualsY=
SOURCE: We have a SCX 4826FN and we can not receive faxes
its may be the problem related to Toner Exhaust, Internel Memory is full ........... so try to check after clear the memory from Tech Mode
Menu#1934 select clear memory from the list.
after that this preset pls. change the cartrige unit or Purchase the Catridge Refill Soltuion.
