SOURCE: im upgrading my samsung sens
Here is link for drivers:
http://www.samsungpc.com/products/x05/x05_supporteddrivers/x05_supporteddrivers.htm
SOURCE: Samsung P30 laptop memory upgrade -- how to
At the back of your laptop after you turning upside down then gently unscrew the screw that is holding a small path covered then loose the screw and you find them in their slot ok gently pull the two metal clip side ward and it flip out then replace it ok
SOURCE: I want to install Windows 7 on my laptop, it
If you are updating from Winos XP orsome higher version to Windows 7, an automatic update is run which backup allthe data, installed files and saved application settings.If you freshly install Windows 7 inyour PC, it will remove all the installed applications and saved settings.
SOURCE: i have to download audio
You can download the device drivers from the Samsung WEB site. Please click on this link and selectyour model computer/notebook and the Windows drivers you require :-. http://www.samsung.com/us/support/
SOURCE: where i can download drivers
You can find the drivers for the Samsung P30 at this URL:
http://www.samsungpc.com/products/p30_p35/p30_p35_supporteddrivers/p30_supporteddrivers.htm
Alex
