How to rapidly delete batches of inbox messages
Visit non-commercial source:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/outlook-express/538-%E2%80%8Brepair-outlook-express-dbx-file
Hi! Follow these steps to get the information:
1. Re-create your mail folder hierarchy by dragging folders into place in the Folder list. Note that any folder you have created to group sub-folders but that does not itself contain messages will not appear in the Folder list and so must be created again.
2. Re-download the list of newsgroups from each news account.
3. Reset your subscribed newsgroups and download messages again.
4. Reset synchronization options on IMAP and newsgroup folders.
5. Edit any message rule that moves or copies messages to folders other than the Inbox.
Also you can use: Easy Outlook Express Repair
Free-to-try version is available here: http://www.mail-repair.com/
Easy solution. My computer was recently infected. I was lucky to find the answer, Here's the link if anyone needs it in the future
http://ryanfrost.paretologic.revenuewire.net/pldrp/homepage
Come back deleting oe messages by use of outlook express folder fix
After reading http://www.oemailrecovery.com/repair-outlook-express.html article your problem must be solved
To recover deleted Outlook Email messages, you need a outlook express dbx recovery software, with the help of this tool you will get all your lost emails.
http://www.recoverfilesdata.com/outlook-express-dbx-recovery.html
Download the free trial version to see results.
Thanks
If you are unable to restore emails from outlook it might be corrupt. You can try Recovery Fix for Outlook Express Recovery tool.This completely scans the damaged
mailbox file and revives the lost emails. & recovers your
accidentally deleted messages that have also been removed from the
"Deleted Items" folder in Outlook Express.
Go to http://www.recoveryfix.com/outlook-express-recovery.html
Hope it Helps
Thanks
SOURCE: self deleting emails
Actually they are right but they are only telling you half of the
equasion. Here is what is most likely going on. I'm about 80% sure.
Norton antivirus is a very weak antivirus system. The only thing it
catches is the common cold. Now as for outlook. Yes outlook is very
vulnerable to Virus attack. I use Thunderbird if I ever use a program
for E-mail. I use Gmail or Yahoo myself but you can continue to
frustrate yourself with programs like Outlook if you like. If you must
use antivirus to protect yourself from Micro$oft then use Avast, Spybot
1.5, and Clamwin. You will need to configure them properly to get them
to work.
There is another way. You can stop using Micro$oft products and
download a Free Operating System that does not get viruses or get
fragmented. It also comes with Thunderbird. It's called Ultumix.
If you want Ultumix do the following:
If you have a Desktop PC connected directly to the internet (not dial up) and a DVD burner I would recommend you go to www.mindblowingidea.com, click Ultumix, and give it a try by saving the Torrent Download Link. Then go to www.download.com and install uTorrent. You will also need to go to www.burn4free.com
and install it as well. Make sure to open burn4free after installing it
as well and select English. Then you may close it. Open the torrent
file you downloaded in uTorrent. After you save the .iso file to your
hard drive (this may take an hour or a day) right click on the .iso
file and click burn4free and then Burn ISO. You will need a DVD-R or
DVD+R in your DVD drive. DVD-R is recommended. After this reboot your
computer and make sure to boot from the DVD drive. You may need to
press additional keys during start up to get this to happen. You will
see a menu that says PCLinuxOS 2007. Select LiveCD and press enter
(this mode will let you try Ultumix without installing it on your hard
drive). Now it will ask you some questions about your computer like
what language you speak. You will most likely use Ethernet as your
internet. Now you will see a screen to log in.
To try Ultumix without installing it to see what it will be like click
on Owner and then type owner all lower case in the password field and
press the enter key on your keyboard. Please note that it will run much
slower than normal in Live Mode. When you install it it will run much
faster. If you try the programs on the desktop and like them you may
want to install it. We will get to that later. Open the icon marked
internet and use it to get to www.hotmail.com. Get into your e-mail. If
that works you should be happy. At this point I would like to point out
that even though this system can't get viruses or fragmentation (unless
you fill the partition over 95%) Firefox can be affected by some
spyware and or trojans. If this should occur you simply click Tools
> Clear All Private Data > check everything > Clear All
Private Data Now.
If you want to install this on your computer you can also leave Windows
on as well but you will be asked if you want to run both during setup.
Click start and log out. Now click the root account and type in root
all lower case. Click Install PCLinuxOS. Go threw the wizard and follow
the instructions. You have the option of resizing your Windows
partition and using the rest for Ultumix or erase everything and start
over. Ultumix can run most windows 95, 98, and 2000 programs in WINE.
You will also find that it can run some XP programs as well like Office
2003.
Have fun. If you still want to live with Micro$oft software reply to me
again and I will walk you threw the painful process of protecting your
computer. You will need to repeat this process I give you every 12
months or less to keep your computer running. You should also be told
that in 6 months Microsoft is planning to stop extending service to XP
users.
SOURCE: rgarding outlook express 6
Solution is posted in the Microsoft support site
The link is given below :
http://support.microsoft.com/kb/321505/en-us
If you dont want to open the link :
RESOLUTION
To resolve this issue, contact Network Associates for an upgrade to the latest version of VirusScan that is compatible with Outlook Express.
For more information about how to update your VirusScan software, visit the following McAfee Web site:
http://download.mcafee.com/updates/upgrade_patches.asp
Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information.
To recover the data from the Inbox.dbx file: •
Restore the Outlook Express store folder to its original location from your backup.
-or-
• View the Network Associates "Outlook Express Inbox Corruption" article that addresses this issue.
To view the article, visit the following Network Associates Web site:
http://www.mcafeehelp.com/displaydoc.asp?docid=60743&CategoryId=269
Note This article provides information about DBXtract. DBXtract is a recovery tool that you can use to restore corrupted Outlook Express e-mail folders. Other recovery utilites are also available.
For a complete list of the available tools, visit the following Web site:
http://www.windowsmarketplace.com/Results.aspx?collID=91
Good Luck.
Live, Love Laugh.
SOURCE: Outlook 2003 restores deleted email files
Thats very strange,
Please open your outlook 2003. Then go on Deleted items, Rt click on properties.
Then check the option if you have done Restore defaults, then uncheck it.
Regards
ELLIN
SOURCE: Windows XP ''Search'' utility disabled. Outlook problems.
If you attempt to send a message that is too large for your
mail server you may be unable to delete it from the Outbox.
First, try setting Outlook offline using the File, Offline menu. Wait
about a minute or so or close Outlook and reopen.
If you are unable to delete the message while in offline mode or cannot
go into offline mode, you'll need to change your default delivery location Try this,hope it will work for you.
Thanks
SOURCE: Outlook Express Problem
Short copy & paste from the site how to disable Outlook Express compact (not completly tho) in the registry:
HKEY_CURRENT_USER\Identities\{long number}\Software\Microsoft\Outlook Express\5.0. In the right hand pane and find *Compact Check Count* >right click>modify>decimal>and set the value to 0, (zero). This will reset the prompt, and you won't see it again for another 100 closings.
