Question about Yamaha Electrical Supplies
Yamaha MZ2300 generator won't start
Won't start
5 Related Answers
Anonymous
SOURCE: My generator will start if I spray it with either
Main jet is clogged
Posted on May 27, 2011
thesnooper
  • 342 Answers
SOURCE: Generator won't start. Seems to
have you had the generator stored with fuel in the carburettor since its last use if so the fuel goes bad and blocks up the main jet, remove the float bowl and clean out all the residue you can clean out the main jet with a suitable piece of wire
Posted on May 30, 2011
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: My generator won't start. I
Check the oil and make sure it is full. (probably is) Engine has a low oil level sensor that will shut off / kill ignition if the oil level is low.
Then pull off the carb air cleaner and float bowl. Catch the gas in a spray paint can lid.
OLD fuel turns into like a shellac and you will need to use carb cleaner and just do a good cleaning. Make sure you clean in the threaded area of the bowl nut as the main fuel jet is there and will need to be cleaned. Look into the intake of the carb. Bottom of the carb you will not some brass tubes / holes. Spray those out with carb cleaner. Check fuel flow from the fuel tank after cleaning. It should be at a rapid gravity flow rate.
Do this test with your gas you have in the paint can lid. Pour enough fuel to make about a 3 inch puddle after spreading on cement.
Use a long stick and dip it in your gas tank until the end of the stick is just coated with fuel. Light the stick end and touch it to the puddle... If you don't get a good flash / poof (i.e burns like a tiki torch) The gas is old. Drain the tank and the main fuel line. Then add fresh gas.
CHECK compression. Make sure that you feel a vacuum at the intake when cycling the engine thru spark plug installed.
If this does not work let me know I can still help you.
Kelly
Posted on Jul 18, 2011
Mr BrokRench
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
stewbison
Richard Morris
  • 577 Answers
SOURCE: I have a 5500 ppg
Hello, ushicks/me hillybilly. One question how old is the fuel in then generator tank,Hey. If it has a fuel filter replace it. Modern gasoline is junk fuel and after a few months it looses some chemical proprieties. GB...stewbison
Posted on Sep 29, 2011
Whirlpool WGD6200 won't start
When you say it won't start, do you mean it won't heat up or do you mean it won't spin?
Nov 07, 2012 | Dryers
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
When you push start button nothing happens
see this causes and fix it. God bless you
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
Sep 28, 2012 | Washing Machines
My Kenmore H3T washer will not start. When a specified wash cycle is chosen Time of Cycle is displayed but the light for the cycle only flashes and washer will not start. No error code is displayed.MO
Sep 27, 2012 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My 4 runner starts sometimes and won't other times, it justs cranks over but won't run
As with any no start issue, you will need to check for spark and fuel pressure when it won't start to know how to proceed.
Aug 19, 2012 | 1997 Toyota 4Runner
2002 saturn sl won't start, turn over but won't start
Done cars have a kill switch if they are low on oil. Check your oil. If the oil is good, it may be the ignition switch.
Jan 01, 2018 | 2002 Saturn Sl
Replace starter and battery 1999 Mazda 626 still won't start
Won't start or engine won't turn over and try to start?
Aug 06, 2011 | 1999 Mazda 626
Electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
electronic key on 2008 jeep cherokee says key damaged or key not programmed. car won't start. some things work but radio won't come on. etc..
Jul 24, 2011 | 2008 Jeep Cherokee Grand
Electrical Supplies Logo
74 people viewed this question
Top Yamaha Electrical Supplies Experts
Sheldon Dedek
Dan Horsefield
Dan Horsefield
Robert Wooley
Robert Wooley
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
