SOURCE: cant get oven to work
hi
Step 1: Take out the screws that hold the panels, and pull off the control knobs. On the control panel the knobs are friction-fit; pull them straight off. Some knobs may have setscrews in the base of the knobs; back out these screws using a screwdriver or Allen wrench and pull off the knobs.
Step 2: Remove the back service panel on the control panel by backing out a series of screws around the edge of the panel. To remove the front panel, take off the control knobs and remove a series of mounting screws that hold the decorative panel to the frame. These screws may be hidden by molding or trim; pry off the molding or trim with a screwdriver, or take out several screws.
Step 3: To gain access to the burner assemblies, remove the burner grates and then the top of the range. The entire range top should either lift up and off the range or open up and back on hinges. The oven door can usually be removed by pulling it straight up off the hinges on both sides of the door. Some hinges have a latch that must be unlocked before the door can be removed.
Step 4: If the surface light of the range burns out, remove retaining screws and panels as necessary to gain access to the bulb. Replace the burned-out bulb with a new one of the same type and wattage; check the ends of the old bulb for this information. Then replace any retaining panels.
Step 5: If the oven light burns out, unscrew it and remove it from the oven. Replace the burned-out bulb with a new one of the same wattage, made for oven use.
SOURCE: oven turning itself on
sounds like a short in awire or possibly the control panel, definatly not a normal issue and for sure is cause for alarm. i would strongly reccomend calling the manufacture and raise concerns for the safety of your home and moreimportantly your family, they take these sort of safety concerns VERY seriously(consider there position of liabilty incase of accident) ..
SOURCE: The Maytag gas oven Model: MGR4452BDW and Serial:
Are you sure it's clean/ Does the smoke smell like wire burning or plastic? Is there a chance that there is some left over spill just burning off?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: I have a maytag stove oven and i want to know how
Hi, here the link to your Installation Instructions:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Installation%20Instructions%20-%208101P624-60.pdf
It also states on page 8: "See Gas Conversion
Instructions located on the back of the range in the Assembly Kit."
Best of luck
