How can I align the color in my tv
SOURCE: Warped Picture, Separated colors
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
SOURCE: Philips Projection Screen TV Model PTV915 Horizontal Alignment
Problem solved, needed to get the universal remote i was using set up with the proper code. Once I did that I was able to use the remote to set up the single & multi-zone Red & Blue Alignment. I also pulled the back plate off and manually adjusted the RGB focus knobs. It seems to be working just fine now.
Thanks to all the other posts.
SOURCE: my hitachi 60SBX72B having picture convergence problem, how to fi
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
SOURCE: I have a philip magnavox model 9p5034c103 and the
what is the diffrent between nokia ultra and flexi bts.
SOURCE: Phillips Model 60PP9100D/37
Its a common problem on this model. Most likely the HVG. Goto www.TvRepairKits.com for a kit with instructions.
