I also had my radiator flushed & and thermastat takin out, it was running good 4 a week after but then it started running hot so I parked it.
SOURCE: New clutch installed on my
Sounds like air has gotten into the hydraulic clutch system, or it is low on fluid from a failed master or slave hydraulic clutch cylinder or connecting line between the master and slave cylinders.
SOURCE: overheating dodge ram
dodge tends to run at about 200dg. i have a 97 with a 318 and this hs been its normal temp since it was new . if it is truly over heating and if the warepump is bad you shoul see water leaking from the bottom of pump . hope this is helpfull
SOURCE: 2001 V10 FUEL , MY TRUCK WONT START AND WHEN IT DID IT HASITATED
i have a 201 ford excursion for about 2 weeks i could not get it to start in the mornings it was hesitant and would take about 4 tries before it would start. i took it to the dealer and they said the battery was fine i ended up changing all the spark plugs and ignition coils and now the car wont start at all.. please help if anyone knows what it could possibly be.
SOURCE: 1994 Chevy Silverado temperature guage shows hot
Flushing the radiator, replacing the radiator cap, adding new coolant, replacing the sensors and a new thermostat solved the problem. Probably didn't need to do all of these things - but since we just purchased the truck, and given the fact that is probably hadn't been done in a while, we chose to do all of these things (which really didn't cost a whole lot), it's running like a charm now.
SOURCE: 99 olds bravada. just replaced fuel pump 2 weeks
Aftermarket fuel pump failure? Try "thepartsladi" store on eBay for low price GM OEM parts. Could also be wiring harness to fuel pump.
