There are too many to count.
Starting in about 1985, when cars & trucks began to have plastic and fibreglas parts, separate ground wires ran from every electrical part to the "universal" ground wires, that ran all over the vehicle.
Have a knowledgeable mechanic show you these.
God bless your efforts.
the connector is the same on both the old harness and the new pigtail. As long as you orientate the connectors the same way you just match up the wires. let me try to explain it this way. If you hold the old connector so the part that holds the connector to the sensor is facing up. Hold the new connector exactly the same way. cut the left wire on both and connect the new connector wire to the old wiring harness. Then cut the center wire and connect them. then cut the right wire and connect. No wiring diagram needed.
One thing I will add is to stagger the new connections. Meaning do nut cut them at the place. Cut one wire then cut the next about an inch or so further and then cut the next about an inch or so further than that. This will prevent the new connections from potentially shorting to each other and will keep the harness from becoming really bulky with all the but connectors in the same location.
Hello... I will try and help you with your problem. I am assuming that you have cut the factory harness off in the truck? If you have and you can reconnect it, I would recommend doing this and then you can purchase a wire harness adapter and then just match the colors. The benefit in using an adapter harness is the ease of the installation, and the more you change the radio in the truck, the shorter the wires will get. If you do not have the factory harness, or cannot reconnect the old one, here is the hardwire code:
Wire purpose: Truck color: Alpine harness:
Constant 12V+
Blue/Yellow Yellow
Switched 12V+
Gray Red
Ground
Brown Black
Illumination
Green N/C
Dimmer
n/a N/C
Antenna
Right Front
Front Speakers
6 1/2" Doors
Left Front (+)
Pink White
Left Front (-)
Purple White/Black
Right Front (+)
Light Green Gray
Right Front (-)
Blue Gray/Black
Rear Speakers
6 1/2" Rear Corners
Left Rear (+)
Black Green
Left Rear (-)
Yellow Green/Black
Right Rear (+)
Red Purple
Right Rear (-)
White Purple/Black
For Dodge Neons: Factory in-dash wire harness has 2 pc harness (black
plug and gray plug).
(Black plug) Rear Right speaker -:
Blue w/White stripe Rear Left speaker -: Brown w/Yellow stripe Front
Right +: Purple Front Left +: Dark Green Rear Right speaker +:
Blue w/Orange Stripe Rear Left speaker +: Brown w/Blue Stripe Power
Antenna/Amp: White (Gray Plug) +12v battery wire: Pink or Pink
w/White Stripe +12v Ignition wire: Red w/ White Stripe Front
Right speaker -: Blue w/ Red Stripe Front Left speaker -: Brown w/
Red Stripe Metal braid plastic connector attached to back of radio
is the ground wire.
ARE YOU AWARE THEY MAKE A VERY INEXPENSIVE ADAPTER HARNESS THAT HOOKS UP TO THE FACTORY HARNESS, NO WIRE CUTING,CAR AUDIO SHOP CAN GET THE ONE U NEED, ABOUT $12. HERE IS THE WIRING COLOR BREAKDOWN OF THE DASH HARNESS. 2002 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange Car Radio Switched 12v+ Wire: Ignition Switch (The radio harness does not provide a switched power source. Run a wire from the Ignition Switch.) Car Radio Ground Wire: Black Car Radio Illumination Wire: Gray Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: Pink Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Tan Left Front Speaker Negative Wire (-): Gray Right Front Speaker Positive Wire (+): Light Green Right Front Speaker Negative Wire (-): Dark Green Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown Left Rear Speaker Negative Wire (-): Yellow Right Rear Speaker Positive Wire (+): Dark Blue Right Rear Speaker Negative Wire (-): Light Blue
Constant 12V+
Red
Switched 12V+
Red/White
Ground
Black
Illumination
n/a
Dimmer
Orange/White
Antenna Trigger
Yellow
Antenna
Right Front
Front Speakers
3 1/2" Dash
Left Front (+)
Green
Left Front (-)
Green/Yellow
Right Front (+)
Purple
Right Front (-)
Purple/Yellow
Rear Speakers
6" x 9" Rear Deck
Left Rear (+)
Brown
Left Rear (-)
Brown/Yellow
Right Rear (+)
Blue/Red
Right Rear (-)
Blue/White
And Here is the Chart for the radios wiring
Red 12V+ Switched power Grey Right front speaker + Grey with black stripe right front- White left front + white with black stripe l/f - Purple R/R + Purple with black stripe R/R - Green l/r + green with stripe l/r - Black ground orange illumination yellow constant power
Its simply called the wiring harness, but what it less simple, is sometimes finding them. You might try just to Google the model and put ''wiring harness'' at the end, or try the companies website if available. I have seen some wiring harnesses in places like Pep Boys, but unfortunately, people usually end up buying a new player. Hope this helps and good luck!
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not
provide a switched power source. Run a wire to the fusebox for switched
power.
Car Radio Ground Wire: Black/White
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink Car Radio Accessory Switched 12v+ Wire: Blue Car Radio Ground Wire: Gray Car Radio Illumination Wire: Red/Blue Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Blue Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Black Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Light Green Left Rear Speaker Negative Wire (-): Violet Right Rear Speaker Positive Wire (+): Blue Right Rear Speaker Negative Wire (-): Pink -->
