See this causes and fix it. God bless you
Door Switch
This can cause the washer to agitate but not go into the spin cycle. You will need to remove the door switch
to check it. You will perform an ohm reading on the bottom terminals.
The reading varies from manufacturers most Frigidaires is around 1500
ohms others like the whirlpool duet is checked at the main control board
with the door closed should be around zero ohms. You will need to refer
to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console.
If the door switch tests good the main control is usually the problem.
Check all connections for a goood tight fit. You will need to refer to
the tech sheet or service manual to check this further. The main control is easy to replace.
Motor Control Module
The motor Control Module is located inside the cabinet down near the
motor. This recieves the signals from the main control module then
relays this information to the motor. Check all connections sometimes a
communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
