Marantz SR-5200 Receiver Logo
Question about Marantz SR-5200 Receiver
My marantz sr 5200 has stuck in "Mute on" situation
It does not turn from "Mute on" to "Mute off" situation when I push the button from the remote either from the amplifier. It is always in Mute on,so, no sound from the speakers.
Posted by Fotis on
Anonymous
    Sergeant:
    Champion:
  • 274 Answers
Your mute switch has been broken some how,End will have to be replaced.
Posted on Oct 12, 2012
4 Related Answers
SOURCE: Marantz sr 500 going to "protect" mode when on.
Change the audio amplifiers IC´s because are on short circuit
Posted on Oct 02, 2008
Anonymous
  • 71 Answers
SOURCE: Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Posted on May 31, 2009
Anonymous
SOURCE: Hi there. I have a Marantz SR-82 Receiver that
Hi, try to turn down the input balance knob, I think you have overloadet it.
Posted on Mar 19, 2010
Anonymous
  • 961 Answers
SOURCE: no image, only sound when
Whatever video components you have, they should be, depending on inputs on TV, should be run to TV first. Recievers do have pass through ports but, are not the best way to achieve picture and sound. HDMI cables are great but you r reciever may not be able to transfer the video. What I suggest is taht you run your componenets, cable/sat box, DVD, etc. via HDMI, componenet, etc., to TV input, then, run audio out from TV, via(best) digital optical. You can use TV's menu to choose what you watch while, you only have the one input to reciever. Scan your recievers menu to make sure you have selected the proper mode(TV, Aux, Vid2, etc.).. If you run your video unit to TV with component cables, you will have to get your sound through separate cable(s). Component cables have graet video, but do not carry the sound.
Posted on Jun 14, 2011
Just picked up a Marantz SR-19, Everything looks like it works but I get No sound out of it. Unfortunately, there is NO remote and was wondering if there is a setting like Mute or a speaker select on the...
A Mute indicator would tell you if it was muted. Make sure no Tape or Multichannel Input are selected by mistake.
There are supposed to be jumpers across the Pre_Outs to Main In's in the back when you're NOT using external amps. You could substitute short RCA cables.
2answers
No surround modes produce any sound . only have sound on s direct mode. marantz sr 5200
Not having the ability to look at it on the bench, more than likely your DSP chip is bad. If you have a local repair house that is willing to confirm that is the problem without charging you an arm and a leg, that's your best bet. It is an expensive repair, anywhere between 300 to 500. At that point, I would say to replace the unit. Sorry for the bad news, but that's my "best guess" The only other thing to check would be your "Audio input Settings" Make sure it's either on "Auto" or whichever type you are using. "Digital Coaxial", "Optical", or "Analog" (RCA) hope this helps! If you have any further questions, just post a reply and I can help further. Best of luck!
My marantz sr5200 dont reproduce dobly digital signals , maybe junt 2 channels.
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Marantz SR-5200 - Analog inputs only play the right channel
please invert your cable and watch if the problem moved the problem in your cable change it with new one.from any radio shack near you or any electronic store.
SR-5200 owners manual
http://www.retrevo.com/s/Marantz-SR5200-Receivers-review-manual/id/511dj791/t/1-2/
1helpful
2answers
Loss of volume on left channel
Marantz SR 5200/6200 lost audio or crackling on left or right channel except in mode s-direct is now fixed !
The root cause is a defective inegrated circuit on DSP board (the one with digital inputs). To fix it change the chip CS4391 by a new one or better by the improved version CS4392. On my device a capacitor was cut close to this IC : replace one 1uF after changing the IC. For any question search me with my callsing "F5RCT"; i have a spare IC for the one who is able to change it !
I'm amateur radio and engineer
Total loss of sound...what to do?
please repeat your setting first- and then disconnect all speaker out.
connect your speaker one by one until you find the bad one and change it-you can also apply contact cleaner spray over volume control and move it many times-please do not forget yo unplug headphone jack first.
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
