Question about Samsung HL-R6167W 61" HDTV
Erratic picture on Samsung HL-R6167W
I have a Samsung HL-R6167W TV that is about 3 years old...I changed the lamp about 4 months ago and it worked fine for about three weeks..
it than began an erratic behavior or displaying a green screen or a screen with five vertical stripes...I would do the 30 second re-set and
the picture would be fine.....this would not be every time it was turned on ....sometimes showing no problems for weeks then re occuring ...
the tv guide screen and the pip were clear but the main screen was
scrambled or had the vertical lines untill re set.....now I have no picture at all ..Could the lamp be defective again....HELP...NOT HAPPY WITH SAMSUNG.....Ed
Posted by Ed Peneguy on
2 Related Answers
Anonymous
  • 647 Answers
SOURCE: Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Posted on Nov 28, 2009
phil_frye
Philip Frye
  • 295 Answers
SOURCE: I have a Mitsubishi Large
What is your source!
Are you connected to:
1) Cable TV or an
2) off air antenna or a
3) DSS Satelite dish.
When also did this start happening, how long ago?
Blessings always,
A/V Media Tech Guy
Posted on Dec 03, 2009
TV Turned Itself Off - Now - No Power No Lights Flashing
power supply board is faulty need to check the power transistors and fuses u will need a tech to solve this
Samsung HLR6167W no picture/no sound
So don't. Just retire the set and move on with a newer cheaper better set with warranty.
2answers
Picture comes on initially then the screen goes blank. the lamp was replaced about 1 1/2 years ago. could this be caused by the lamp going bad again?
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it :http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The part # is "BP47-00027A" When you replaced the lamp did you replaced it with an Original Philips,if you did those lamps average 6000-8000 hrs 2-4 yrs.But if you didn't get a Philips but an aftermarket or Osram they average only 4000 hrs 1-2 yrs.Have a bless one!
Screen goes blank for seconds
bad connection, soldering goes old .using soldering iron, locate bad connection and redo them agin
Picture on my TV starts to flash after a few minutes of use
This problem is common in Samsung projection TVs. The DMD board is going bad.
Samsung HL-R6167W 61" HDTV Logo
Ekse
Demonic-2011
Demonic-2011
