Question about Radio Shack Wireless Weather Forecaster
Radio Shack Weather Forecaster 63-1090
Outside relative humidity does not change
Posted by GJDGM9 on
1 Related Answer
mbhome
  • 32 Answers
SOURCE: How to set radio shack weather forecaster to accurate time zone
http://support.radioshack.com/manuals/ome63-1085.pdf
Posted on Nov 01, 2012
Acurite weather forcaster not showing outside temp
Here's the manual for the AcuRite Weather Forecaster. If it's not showing the outside temperature, make sure the A-B-C switch is set to match the display unit. Not doing so might be the reason it's not synchronizing and displaying the outdoor temperature. https://www.acurite.com/media/manuals/75077-75107-instructions.pdf
Apr 10, 2016 | Measuring Tools & Sensors
The humidity sensor reads "LL" ... What does that mean for a gro1 digital weather station ?
Humidity value is lower then the forecaster registers , they normally go no lower then 20% . If you are getting an LL that could mean where you are located the humidity was lower then 20%
Feb 18, 2015 | Measuring Tools & Sensors
Weather station won't work
i have the same problem and have had 2 of these now. outside unit blinks like it is transmitting but nothing on base. SYNC per manual does not fix it.
Jan 29, 2013 | Brookstone Wireless Weather Forecaster
Can I replace the sensor for a Radio Shack 63-1090?
I presume by sensor you mean the remote sensor not the main unit which also has sensors? When you buy the 1090 you get one external/remote sensor which is also labeled 1090. If you buy extra sensors they are 1092's. Another new 1092 sensor should work with your 1090 it does on mine. You can have up to 3 remotes just set the channel on them. Getting one is the problem. If your talking of stripping the box down to replace the sensor , well I am sure more than the sensor would have a fault!
Oct 29, 2012 | Radio Shack Wireless Weather Forecaster
How do I reset my 63-1090 Clock
how do i set up my 63-1090 clock need instructions thank bobby woodberry
Jun 20, 2012 | Radio Shack Wireless Weather Forecaster
Radio Shack Wireless Weather Forecaster Logo
220 people viewed this question
Top Radio Shack Measuring Tools & Sensors Experts
Harrie
Are you a Radio Shack Measuring Tool and Sensor Expert? Answer questions, earn points and help others
