Replaced about everything there is to replace and have isolated as much as I can. Need the schematic to trace down the wiring as much as possible.
We do not have wiring diagrams due to copyright laws. You can hiowever purchase a used factory manual here for cheap.
SOURCE: replaced alternator and battery is good but not charging
I found the problem YEAH. It was the fuse that is in the side of the fuse box under the hood, Its where the battery wire from the alternator connects thru a fuse to go to the battery, Its one hundred and something volt fuse. It took care of the problem instantly.... Thank you all for your replies...
SOURCE: 1999 F350 diesel 7.3 single alternator system
you may have a bad plug wire to the back of the alternator you can test that with a light tester but when you replace a alternator in a diesel at start up it takes about 35 secands before the unit will kick on
SOURCE: replaced alternator on 1985 Ford Bonco 4X4 302
turn your vehicle on, disconnect the battery, both terminals(while truck is still on) if it dies on you, then either the alternator is bad or wiring is wrong. if it stays on, then you may have a bad battery or voltage regulator. Check the voltage on the battery before you turn it on(should be from 11.5v-12v), when you turn it on if the alternator if working properly you should have around 13v-14v.
Testimonial: "This was helpful, but I did not post that I had already performed this check."
SOURCE: battery alternator visit workshop is flashing on
MERCEDES C200 Kompressor 2001. battery alternator visit workshop is flashing on trip computer. i have replaced alternator. everything is ok. battery getting charge... i cant see any thing wrong so why workshop flashing?? maybe something wrong with new alternator 4 exampel voltage sensor??
SOURCE: dodge neon 2002. My alternator is not charging,
wires run direct to alternator from battery ,test big lead for a permanant 12v supplyon the back of the alternator if you have one then the problem is either the brushes worn out or the commutator worn through.or the regulator either way its a recon unit as parts are not sold seperate anymore as not many dealer mechanics know how to repair anything and the spares shops make more profit on a unit than parts so they do not sell spares to stop people like me and you from doing our own repairs
