Attempts at booting failed at WRIT memory read/write failure 1FF90040 Keyboard failure
SOURCE: Alert! previous attempts at booting this system
I'm not sure right off hand what the WRIT means. But other articles online seem to think that you should hit F2 at boot and check the Boot Order. One guy set it to CD and booted a CD (a bootable one) fine. I would make sure it set to the first Hard Drive. He also said something about: went to the "event log" section and cleared the last event (actually the only one showing). I saved the settings, then booted up again and this time it booted up normally.
* Anyway new hardware external or internal would be 1st suspect in this kind of thing. One person had problems after adding a new printer that had a memory card in it. Apparently the Dell tried to boot from the memory card.
SOURCE: Dell 8400. previous attempts at booting this
It is a Hardware error, and my be associated with the following components.
SOURCE: my dell dimension 4300 displays
make sure you keyboard is plugged in well. If that doesn't help try a different keyboard.
