Westinghouse TX-52F480S 52 in. LCD TV Logo
Anonymous Posted on Oct 11, 2012
TX-52F480S lines after watching for a few minutes, sometime up to 30 minutes, colored lines start popping up and won't go away. in half the case, after unplugging the power cord, waited 30 sec or so, plugged back in, it would work. then the lines would re-appear after 5minutes or so
Eugene Tetlow
Level 2:
Sergeant:
Champion:
  • Expert 226 Answers
  • Posted on Oct 11, 2012
Eugene Tetlow
Expert
Level 2:
Sergeant:
Champion:
Answers
226
Questions
Helped
77123
Points
550
IF LCD TV has vertical lines try cleaning T-con board to lcd panel cable or replaced t-con board
5 Related Answers
Anonymous
  • 2071 Answers
  • Posted on Jun 26, 2008
SOURCE: tv problem
Your problem is in HOT, Horizontal output transistor is defected already ,this is high voltage transistor , if no high voltage there no picture ,but supply is there because light is flashing ,the supply voltage is trap ,when this voltage go to horizontal section your tv is automatically shut off because defected HOT,,you change this transistor ,so performance will better again ..find a tv repairman to do the works in changing the transistor and little reheating works.
This is better in order to avoid high voltage shock,this not cost much....
Anonymous
  • 187 Answers
  • Posted on Jul 09, 2009
SOURCE: TV appears dead
the mainboard is damaged and need to be replaced
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jan 04, 2010
SOURCE: My TV is 2 years old and the picture colors change
Bad LCD controller (the cover is removed in the picture), see sample here: http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
There are more than one version of the board, you need to match withe the LCD panel number.
Testimonial: "I would like to thank you for your expertise. The solution you suggested was exactly what the problem was. Also thanks for the link to the parts store. It took me the better part of a year to work up to tackling this one as it had been more than forty years since I repaired TV's. Anyway my TV is working again and the wife is happy. Again, many thanks Dennis"
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Good picture for 30 minutes then colors change!
Bad LCD controller, see sample here (note, I removed the cover off the board so you can see it): http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Be real careful when you remove the back cover, the side switch assembly is attached to the back cover, so do not yank it too hard!
Anonymous
  • 120 Answers
  • Posted on Jan 27, 2010
SOURCE: No picture on Westinghouse TX-52F480S.
Hello, I will need a bit more information to help you out on this one. I can troubleshoot with you live on this one just simply email me your contact information to [email protected] or send me an email and I will give you my contact info.
Vizio 32 Inch, turn on completely fine for about 20-30 minutes. Then sound goes out accompanied by high pitch noise and picture has varying lines or colors through it. Won't power off, have to un
Are you a decent do it yourselfer? It sounds like it is the capacitors. What happens is they get hot and expand (the top of the Capacitor). The top will be dome shaped and it will look like the top is splitting open. You can buy (about $1.50 ea.) the capacitors at your local electronics store (not Radio Shack they usually don't have a high enough amp).
You will need to take the back off and look at all of the capacitors to see which ones are bad. Usually it will be 2 or 3 of the larger ones but there could be more. Next you will need a soldering iron with a fine tip and some wicking material. How could are you at soldering and de-soldering? before I go on.
If you let me know the model # of your set I can be a little more detailed also.
I have a Sony FD Trinitron 27' Model # KV-27FV310. It is approx 8 years old. After turning it on and watching a full screen for a few minutes; all of a sudden, a line came across half the screen;
top half missing is in vertical circuit of set---if it is a 27 inch and this old consider retiring it and replacing----other option is consider having a shop repair it--a rough guess would be as high as 150 dollars parts and labor is possible for your problems.
I am hoping someone on here can help me with my problem...My check engine light came on my 2003 Chrysler 300 M special edition and also wouldn't start at times for up to 30-45 minutes at a time, and...
Have you had the battery changed since you had the car. Have that checked for a full charge and no dead cells. Always have the air-conditioning completely off when starting the car. The starter takes a lot of amps to turn over and having the AC on doesn't help.
and another reason is the code didn't clear out completely. this tool can help you test the code.
Westinghouse tx-52F480s. flicker, turned into colored lines. now all black. all inputs. what is the problem. which board?
Most likely the T-CON board it is dead.The tv have colors vertical lines alway causes by a dead T-CON board,if only this problems,happen by the tv itself only.Not causes by u or an object by hitting it with forces,than the tv LCD screen panel it is damages and tv it is worthless as a whole tv set.Because the tvs LCD screen panels are very important to the tvs and it is 90% of the costes of all tvs.The T-CON board sit in the middle at the bottom of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON board for the replacement.
I have a 52" westinghouse
Ok you have a lot of things going on here. Your first thing with the lines can be your T-con board or your Signal board or the screen itself. The second thing black screen you would have to be more specific? Is your back light on and you have no image? If that's teh case then I would replace the T-con board or the Signal board. If by black screen you mean there is no light on the screen from the backlight inverter then your BAcklight inverter or the backlight itleft might be bad. and ontop of that you might have the problem that we started with also. You can get westinghouse parts from www.interliquidparts.com You have to order by part numbers so you have to get the number from the actual part of your TV.
Weird lines on Toshiba REGZA
its in warranty ship it, the problem is actually not common but it is a problem it is related to the processor on the main board, and um don't trust salesmen to tell you about repair issues. They really don't have a clue. if you need a tv for to weeks then rent one for two weeks they are not that expensive to rent
I think it what is called convergence
Maybe loose connection on the convergence board around the IC's or amps
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
